215 V8 engine heads VS range rover heads
I am putting a buick 215 V8 in My spitfire. I have been accumulating parts and I have heard .. that you can use the range rover 4.2 heads (because of the bigger valves and better flow work ) for a performance boost. Does anyone know .. if this actually works? would I gain performance over the stock heads ? Does anyone know if there are any differences in bolt patterns or anything like that ? Any thoughts/suggestions/ideas will be appreciated !
Randy 80 triumphspitfire 74 norton commando 850 72 dunstall 750 71 triumph bonnieville |
Re: 215 V8 engine heads VS range rover heads
I don't think the heads are different. I'm pretty sure the volume is the same too. I think the newer 4.0/4.6 have a 29cc head. You could increase the compression that way for a performance boost.
Apparently the port sizes are almost identical on all Rover heads..
The 1988 to 2004 heads have ever so slightly larger ports. 1/16 on the intake and 3/32 on the exhaust.. but they do have larger valves.. |
> and I have heard .. that you can use the range rover 4.2 heads (because of > the bigger valves and better flow work ) for a performance boost. Does anyone > know .. if this actually works? would I gain performance over the stock > heads? Not much difference in the Buick 215 and Rover heads upt through the 3.9L and 4.2L. Later 4.0L and 4.6L heads were milled to reduce the combustion chamber volume to offset the use of a thicker composite head gasket. They also change from 5 head bolts per cylinder to 4, the same as Buick 300 heads. The Buick 215 heads do not have accessory bolt holes. The Buick 300 and Rover heads have bosses and bolt holes for mounting accessory brackets. I've not had the 4.0L/4.6L heads on the flow bench but I'm told they have the same size valves but with narrower stems underneath the head. You can use them on your 215 or just mill the heads you have for a compression boost. You may need to mill your intake to maintain port alignment, though. Dan Jones |
Buick215/Rover3.5 combustion chamber volume = ~37cc
As Nicolas said, Rover 4.0/4.6 combustion chamber volume = ~29cc (Lucky me, I already have a set of 4.0 heads laying around!) Here's a nifty online tool: [www.rbracing-rsr.com] Playing with it, I see that I could bump my compression ratio from about 8.8:1 to about 10.2:1 by installing late-Rover heads. (Warning: results would vary depending on head gasket thickness, piston dish volume, etc., etc.) With bigger valves and better flowing ports in the bargain, it looks like a pretty good idea to me! --- Here are a couple more numbers courtesy of Des Hammill... 215 and all pre-1976 3.5L valves: 1.50" intake, 1.312" exhaust 1976-and-later-3.5/3.9/4.2/4.0/4.6 valves: 1.570" intake, 1.350" exhaust (From 1982, Rover valve stems were "waisted" for even more airflow too) --- What else should be considered? |
Hi Randell,
I was wondering if you had any photos to share of your 215 going into your Spitfire? My son and I just picked up a 73 Spitfire for him last week. How funny it is that I'm curiuos of what to swap in it already. I have been looking at all the spitfire swaps in the spitfire section on this site. These Spitfire's are a kick to drive in the corners, but lack very big in the pony section. Calvin |
There is actually a very small advantage of the later heads. The ports are slightly straighter .. and it is only slight .. but can make a difference, especially if you intend to port them.
Cylinder head bolt pattern is the same apart from the missing bottom row of bolts which I would recommend that you leave out anyway (or at least do not toque them down) as they have a tendancy to warp the heads and cause them to blow into the valley. Other differences include; 4.0 / 4.6 heads (10 bolt) are 29cc as standard 3.5 / 3.9 / 4.2 heads are 35 - 36cc as standard 4.0 / 4.6 have some extra metal on the end faces with a drilling to take the late type alternator mounting (but you don't need to use them) 4.0 / 4.6 heads have slightly uprated springs (but again it is only a slight difference) 4.0 / 4.6 always have the guid tops machined for the late type neoprene stem seals .. which are much better! Other points of note ... the tin head gaskets occupy about 3cc of chamber and the composite head gaskets occupy around 9cc of chamber .. so the heads are interchangeable as long as the correct gasket is used, or equaly you can alter the compression ratio easily by just swapping gasket type. Shaun |
Howdy Fellas. I'm new here, and to avoid starting a whole new thread to discuss heads for the 215 engine block, i figured this would be the more appropriate place to ask this question.
I am located in oklahoma city and i can't find a set of 215 or 300 heads anywhere. I think the guy at the rover dealers parts department wants to kill me by now for calling trying to find a set. So here is the question. The gentleman i got the 215 block from said that a set of ford 302 heads would fit these engine blocks, but he wasn't sure. will the ford 302 heads mate up to the 215 block? and if not, are there any other heads that will fit the 215 block other than the buick/oldsmobile/pontiac/rover heads? performance heads are great, but right now i would settle for any heads that would function with this block, seeing as how i have none at all at this particular time and can't seem to aquisition stock replacements or any others expressly made for this block within the local area. |
Ford 302 heads definitely won't bolt onto your block... but don't get discouraged! A lot of Range Rovers and Discoveries are being retired these days. Decent used engines are getting easier and easier to find. Sometimes when the engine blocks aren't rebuildable, sellers are willing to let the heads go at a bargain price. Just last week I sent a pair of Rover 4.0 heads to the machine shop - they'll be a nice upgrade for my old Buick 215. Since my preferred machine shop isn't local, I had to ship the heads - so I can tell you the weight for a pair of Rover heads (with valves, springs, and appropriately protective packaging) comes to about 56 pounds.
I've heard that about the 302 heads before. Is the bore spacing for the 215 and 302 similar or something? The other problem there is the need to fabricate something for the intake.
The sequence of ports from one end of the head to the other end is different. How best to explain it? On the BOPR aluminum V8, the intake ports of cylinders three and five (or two and four, if you're looking as the passenger side) are side-by-side. As I recall, on a small block Ford the pattern simply alternates intake-exhaust-intake-exhaust all the way down. As I recall, on a small block Chevy the intake ports of cylinders one and three are side-by-side, as are the intake ports on cylinders five-and-seven. So, even if Ford or Chevy heads bolted onto a Buick 215 block, cam lobes and manifold ports would still be mismatched to valves and head ports respectively, right? Someone jump in here and correct me if I'm confused.
In the meantime, here's a photo of a Ford (aftermarket) head, courtesy of our friend Pete Mantell. You can see the intake ports, and that they're pretty-much evenly spaced along the head. On a Buick/Rover head, the two middle ports would be closer together. |
Jody - My rover 3.9 has buick 215 heads (8k miles on rebuild). If I can find some decent 4.0 heads, I'd be happy to sell you my buick heads.
I must have finally gotten someone who knew what they were doing at the rover dealership because they sent me to a sport and classics shop here in downtown OKC. here's the price comparison for you fellas.
Dealership set of stock, bare bones 215 heads: $3600.00 shipped in from Pennsylvania. Sport & Classics set of 215 heads with all the goodies included/installed, already on hand: $300.00 if thats not a mixed signal on head value then i don't know what is. Thanks Mr.T. If you find a set of 4.0 heads, then let me know and i'll take those 215 heads off your hands. i don't mind rebuilding a set of heads, just need the heads to rebuild. and i could always use a spare/back-up set, just incase Sport&Classic is jerkin my chain. You fellows have been alot of help. just reading through the forums and your responses to my questions. I'll probably have more questions to come as i get deeper into the rebuild for this engine. |
Just for my understanding:
Does tha mean that all Buick 215 intake manifolds will fit on the 3,9 ltr. RV8 as well? Thanks for any Feedback in that. Regards Markus |
Yes, the Buick & Olds 215 intake manifolds are interchangeable with the Rover 3.5-4.6 manifolds.
Saw a reference above to Buick/Olds/Pontiac/Rover. The Olds heads are definitely different and that Ford head stuff is probably a corruption of a reference in the March 1985 Hot Rod Magazine article "Affordable Aluminum V8" to using Ford small block valves in the aluminum V8 (available on-line). That reference was for the Olds head. Good advice as the Ford valves were 1.67/1.44 and dirt cheap. Some Buick stuff. Dated material but a good pre-Rover read anyway.
Good advice for anyone looking for Rover V8 cylinder heads is to look on;
[www.ebay.co.uk] or [www.ebay.co.uk] If Curtis is correct with the weights of the heads shipping would be; [www.parcel2go.com]|75|30|30"etype=Default#/results It looks like it would be possible to buy a pair of 3.5 heads and ship them to the USA for about $140 Philip |
