Re: Rad cap mounted temp switch
Slight problem. The crossflow radiators have the fill neck on the suction side. (Of course dummy.) This doesn't work at all. Too bad though, it seemed like a clean solution. Maybe with a much cooler switch point.
Might work with a downflow but only if the fluid can be kept in contact with the bulb. Well, thanks for the assist guys. Fun, if not successful. Jim |
Seems to me that late model MGB's had the fan sensor stuck in a hole in the upper tank (forward face) and retained with a wire clip. If you're going the soldered bung route, why not solder it into the pressure side end tank, similar to original. Your fan switch needn't be so long and more available, then.
Yes, it is flat on the end and with some heat sink paste could simply be clamped to the tank. I will give it some thought. Maybe a fairly simple "C" shaped clip with a threaded hole and screw in the sensor as the clamp. Could be a good idea. Make it out of about 10 ga. aluminum maybe.
I have one like Ivor posted tied to my OEM electric fans with the probe stuck way up into the upper hose. This is as a backup to my engine fan.
I have a temperature switch that is on a probe that fits into the radiator fins (air space) not water space.core. It is about 1/3 down from the top and works just as intended. It is easy to experiment by inserting it in different parts of the radiator...
You might want to put some heat paste on the sensor where it contacts the rad, make sure it picks up the temp.
[www.amazon.com] Ivor |
Yeah, I did that but thanks. I need to go back and short the leads to make sure the fans activate. They should but I'm still not getting the right results. More later.
Have you checked it out with an infrared heat gun Jim?
Probably the easiest way to home in on the sweet spot. The heat loss around the sensor might be too much as well. Might need some sort of insulation to function correctly. Cheers Fred |
Turns out the switch was the wrong spec. I'll need to find one that turns on at about 185 and 195F. I think it's a 22 x 1.5mm thread.
You need the early VW Audi rad fan switch Jim.
Dual range, 95/84 - 102/91 degree C, on /off temps. 22 by 1.5mm thread. Will run a 450 watt fan without a relay but I always put one in anyway. Part # 321 459 481A Cheers Fred |
Thanks Fred (just sent you a PM btw)
If I could get one just a little cooler than that I think i'd like it better. Jim |
