Re: Gear ratio calculator, rear gears, and transmission ratios
Rob, Is your Edelbrock the 4 barrel type or front throttle body? Do you know the injector size? Stock 302/5.0 was 19lb. Most use 351 size 28lb.
Jim, the ProFlo is port injection. Throttle body is 4-barrel type with 1000 CFM # 1.5" hg. Injectors are 29lb Pico type.
Rob, a few more questions. Average runner length and port height. Then I can input custom and get a closer dyno chart. It sounds similar to what we did for Chris Gill on his stroker Buick. I think your B cam advanced is the best choice. Why buy another that is close to the same performance?
Edited 1 time(s). Last edit at 11/18/2017 10:53AM by mgb260. |
Can't seem to find that info online and am away from the parts till sometime next week so won't be able to measure till then. I vaguely recall reading somewhere that the Pro Flo intake is based on the Victor Jr. but not 100% sure if my memory is right.
Rob, Your cam has 5 degrees advance built in. The Comp cam has 4 degrees advance built in. Even though they are put at zero the advance is already there.
Dan Masters uses the E cam with his Edelbrock Pro Flo injection. A little less duration and more lift than the B cam.
I knew Dan has an E cam and he is happy with it. But, if I'm going to swap cams, the XE264 or 266 seem like better choices. Either way, I'm going to try it with my existing cam. I'm just not sure how well the EFI system will like it.
Rob, I agree with the XE264 but the higher lift on the XE266 makes me worry about piston to valve clearance, for a small gain in power.
From my experience, the XE 264 HR is perfect for a EFI street car. As Jim noted earlier, the carbed and EFI Dyno very close. Larry Shimp and I confirmed this several times. Same engine combo, Carb vs EFI. No P to V problems. E & B Cams= OLD School Tech. OK to move up to early 21 Century tech. :-)
B-B-B-B-but Kelly.......
Edited 1 time(s). Last edit at 11/20/2017 06:38PM by MGBV8. |
Yeah, yeah Carl... Kelley already sent that to me to harass me. You guys have convinced me. Need to swap transmissions and resell my current one before I can buy a cam.
Edited 1 time(s). Last edit at 11/20/2017 07:49PM by rficalora. |
Carl, that video "kills me", LMAO
brings a tear to my eye...
M.F!, never thought of using a B cam for "Tenderizer" Other good attributes including the Aliens and Mother Ship. Is there anything the Mighty B Cam cannot do????? Insert where?
Happy Thanksgiving to all! |
Rob, Just a bump to see how you're doing on the transmission / rear gear change?
Between the house flooding, selling a house (twice - long story!), some house remodeling, and moving our stuff -- on top of working 50-60 hrs/wk, I don't even have my cracked windshield from BV8 2017 replaced. I got as far as getting the new glass in the frame but stalled after that. I did figure out that my water leak on the passenger floorboard is due to how I grafted the metal dash cowl into my RB shell... There's a u-channel under the dash that's close to the middle wiper post. The wiper bar that runs under the cowl to the posts is being fouled by that U-channel keeping the middle and right wiper posts from seating properly. So, I need to cut a relief in the channel.
Back on gear ratios, Kelley & Carl convinced me my rear gear with a 2.95 1st gear works well. So, I bought a T5Z spec transmission in a SN95 case so swap should be pretty easy. Remodeling will have a break after April and we finish our move at the same time so I should be able to get back on the car after that. Realistically, I expect to get the transmission changed and maybe the cam swapped before BV8 2018. But, very unlikely I'll do the EFI swap till after that. |
Rob, Sorry to hear about your troubles. I was just curious how you were doing. I'm starting a 10 day stretch 12 hours a day my self. Good news is I get to retire in 20 months!. Did you decide to go with taller tires? The smaller diameter tires lower your rear ratio too.
