kanabyte
ronald Smith
(2 posts)
11/04/2017 03:57PM
5.0 302 Rover Jaguar pushrod V8
Posted by: kanabyte
Date: November 04, 2017 04:09PM
I am an old America Hot rod fan and would need to get my facts straight (hard to do at my age).
Is the Rover 5.0 V8 a Ford V8? we used to call them 302s in my cubic inch past and they were push rod V8s and still are over here in Mustangs, Pickup trucks, and the like.
I think if I understand correctly that when Ford bought Jaguar/Rover the aforementioned V8 was put in the Jag and called an AJ8? is that correct?
Flowing on it made it's way into the Rover too?
Is the top end Rover (the one with the supercharged V8) still using a ford drive train?
Thanks and please forgive my olzheimers disease.
K
kstevusa
kelly stevenson
Southern Middle Tennessee
(873 posts)
10/25/2007 09:37AM
Re: 5.0 302 Rover Jaguar pushrod V8
Posted by: kstevusa
Date: November 04, 2017 06:39PM
According to google search, the Jaguar AJ engine is ALL Jaguar design and not Ford related. I think the original design was named AJ26 and later AJ types numbers consecutively. Started out as 4.0L and increased later and updated designs. They were DOHC engines with steel liners and VVT. Some Ford models used the ZF tranny and a modified Jag design engine in the Lincoln LS, T-Bird Super Coupe to name a few.
kanabyte
ronald Smith
(2 posts)
11/04/2017 03:57PM
Posted by: kanabyte
Date: November 05, 2017 07:35PM
OK... I thought Ford put the 5.0 push rod V8 in the Jag too.
Any autos made over there that also use the same Ford push rod V8 besides the Land Rover?
We don't have a factory supercharged 5.0 on this side of the pond as far as I know. Ford seems to be promoting the 3.5 Eco Boost V6 for top end power... instant 500 ft/lbs of torque.
For trivia the 302 (5.0) started out over here as a 221cu in and became most popular as the 289 and then as the 302 in Mustangs
thanks all
donkelly23
Don Kelly
Charleston, SC
(111 posts)
07/21/2011 05:13PM
1980 TR7 V8 Z28 FI ECM 4.0
Posted by: donkelly23
Date: November 06, 2017 05:27PM
the 5L Rover is a Ford power plant?
(3509 posts)
79 MGB, Buick 215
Date: November 07, 2017 11:03AM
No. It is my understanding that the new Rover 5.0L V8 is a Jaguar engine.
Johan3500
Johan Van Wyk
(9 posts)
03/06/2009 06:17AM
Posted by: Johan3500
Date: November 27, 2017 04:10AM
No. The Ford 302 was a cast iron block design, whereas the Rover was originally a Buick 215 all aluminium engineBritish Leyland in late 1960's. Also: no. 1 cylinder on the Rover/Buick is the front cylinder on the left hand side of the engine with number 2 front right hand side (like a Chevy), whereas Ford no 1 is front right hand side and number 2 cylinder is also right hand side, second from front, then 3 then 4 closest to firewall. Cylinder 5,6,7 and 8 are all on left. Rover, like Chevy is criss-cross.
I hope this helps
