Ford 302 distributor with 7-1 cam position sensor in it?
Date: November 06, 2017 07:20PM
Apparently I need one for the Edelbrock Pro Flo system. Would prefer to get an OEM distributor rather than the Mallory unit Edelbrock originally included with the kits.
Edited 1 time(s). Last edit at 11/06/2017 07:21PM by rficalora.
Re: Ford 302 distributor with 7-1 cam position sensor in it?
Date: November 07, 2017 07:07PM
No one, eh?
How about a follow up question... Anyone know if the small cap can be used on a 1990 Mustang TFI type distributor?
pcmenten
Paul Menten
(242 posts)
10/08/2009 10:40AM
Posted by: pcmenten
Date: November 08, 2017 12:43AM
Rob, I remember seeing something like that and I'll look to see if I can find out what the application was, but, as I'm sure you know, the reason for the large cap was to prevent arc-over between the posts in the cap.
Going from memory, the large cap was actually fitted with an adapter and a smaller cap could be found to fit the body of the TFI distributor.
Paul
Date: November 08, 2017 08:00PM
Thanks. I know they went to the larger cap to prevent cross over but i've been runnimg a small cap with no issues. I need the small cap to clear my drop based air cleaner.
Since Dan's car has Edelbrock's Pro Flo on it and I recall Ted saying he had to modify the air cleaner, I'm wondering if he did that to clear a big cap distributor.
(2463 posts)
Date: November 22, 2017 07:27PM
Rob, AMC or International had the small cap with stud type terminals for HEI wires. Go to NAPA and get one with brass terminals with matching rotor.
Date: November 23, 2017 12:31PM
Jim - finding small caps isn't a problem. The problem I have is finding a small cap that will work on the later TFI distributors (e.g. 1990 Mustang) that are designed for the big cap style. They are made where the small diameter to large diameter cap adapter screws down to the distributor. The adapter then has the clips on it that hold the large cap on. There are no clips on the distributor body and no provisions to add them. I was hoping to find a screw down small cap but so far no dice.
(2463 posts)
Date: November 23, 2017 01:40PM
Rob, This thread may help you on the TFI cap:
[www.theturboforums.com]
Date: November 23, 2017 08:25PM
I'm going to call UPR to be sure, but from that and several other threads I found, it appears they only did a limited run of their adapters and aren't making them any more.
(2463 posts)
Date: November 23, 2017 08:49PM
Rob, Yeah, but the guy ordered the red MSD #8431 cap (84313 in black) and used the 4 cylinder rotor and it worked. Sounds like the newer MSD cap doesn't need an extra adapter.
Edited 2 time(s). Last edit at 11/24/2017 08:10AM by mgb260.
(2463 posts)
Date: November 24, 2017 08:43PM
Here is some more info on adapting the TFI to small cap:
[www.ford-trucks.com]
Date: November 25, 2017 10:38AM
Great info Jim, thanks! I've read the threads a few times, but am still not sure whether the MSD cap fits directly or needs the adapter. I'm getting the cap and distributor so I can try it. If that doesn't work I have a buddy with a CNC router that can do aliminum so can probably get an adapter made with the diagram in the above thread.
(2463 posts)
Date: November 25, 2017 12:09PM
Rob, The first thread says it bolted right up, the second shows an adapter. I wonder if the adapter was just to rotate it to clear the tunnel ram? The rotor you need is the 2.9 V6 TFI.
Edited 1 time(s). Last edit at 11/25/2017 12:13PM by mgb260.
(2463 posts)
Date: December 10, 2017 03:21PM
Rob, Did the cap bolt up or did it need an adapter?
Date: December 10, 2017 07:31PM
Haven't bought it yet... put it on my Christmas wish list ;). Wife always gets frustrated when I buy something close to Christmas and then have no ideas for a gift.
Scott68B
Scott Costanzo
Columbus, Ohio
(562 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Posted by: Scott68B
Date: December 11, 2017 08:16AM
Hey Rob,
Will your car be ready for Dayton? :) Sounds like you're doing a major update.
Hope you've been well.
Date: December 11, 2017 05:22PM
It'll be ready. No way I'm missing it. My folks are planning to come too (my dad got his undergrad degree from Univ. of Dayton so it's a chance for he & my mom to visit their old stomping grounds). May have to trailer the MG for the first time though as they want to rent an RV & go up together.
