RDMG
Dave R
Northern Virginia
(138 posts)
04/07/2016 08:29PM
1979 MGB 4.6L Rover V8
New(?) 7.5lb Rover V8 billet steel flywheel
Posted by: RDMG
Date: December 12, 2017 08:50AM
This popped up in my regular auction searches, and I hadn’t seen it discussed here before.
It’s a UK made racing spec piece, requiring a special clutch. Lightest RV8 flywheel I’ve seen, but it does look delicate. About $480 with shipping.
Seems like someone out there with deep pockets might be interested:
[www.ebay.com]
Re: New(?) 7.5lb Rover V8 billet steel flywheel
Date: December 12, 2017 11:26AM
That would be for a 7.2" double or triple disc clutch assembly (also very light). Should work quite well but have little momentum for starts. Probably too light for street use.
Date: December 12, 2017 05:19PM
The problem with race clutches on the street, is they're all-in/all/out, making for a lot of attention getting, you may not like. No marcel and torsional hub , becomes miserable for the street. 2 cents, art.
40indianss
don foote
(83 posts)
08/01/2013 04:35PM
Posted by: 40indianss
Date: December 12, 2017 08:10PM
Seems a little pricey to save 2-3lbs over an aluminum ten lb wheel from d&d. Would the difference even be noticeable on the street? Don't think so
RDMG
Dave R
Northern Virginia
(138 posts)
04/07/2016 08:29PM
Posted by: RDMG
Date: December 12, 2017 08:49PM
All practicalities aside, it is a beautiful piece of machine work, isn’t it?
I have a stock 215 v8 flywheel from a 1962-ish Buick Skylark in my garage. If you were to compare the two side by side, it would be impressive how different the same mechanical part can be.
Date: December 12, 2017 09:32PM
Almost all the weight is in the center so yeah, for racing it would make a difference, especially with the dual disc clutch.
Date: December 14, 2017 07:13PM
All them $'s and NO extra ground clearance ? Looks like the teeth are NOT replaceable.
Blown v8
Bryan Phipps
(72 posts)
03/10/2013 04:52PM
Posted by: Blown v8
Date: January 21, 2018 12:20PM
I've had one of the alloy f/wheel and clutch (d&d)
The alloy one,is a good clutch,(sintered bronze) engine spins quicker,you need to warm up the engine more before driving off.
Otherwise it stalls,it would really suit a circuit car,On a drag type car,it hasn't got the weight/inertia,and it cost me a few tenths of a second !
Gone back to my Mcleod steel flywheel,with ceramic paddle clutch.
I know what you mean about being like a switch,but by changing the master cylinder you can fine tune the system.
You do need a lot of free play with both of these clutches,(2 to 2 1/2" on the pedal)
