Goto Page: Previous12
Current Page: 2 of 2
(2895 posts)
Re: New guy
Date: May 16, 2018 07:39PM
I suspect your Hilborn "butterflys", measure 1.8" dia. ? If so, same as mine. Mine has Hilborn pump and water pump driven, direct by cam. I was at Hilborn, in Laguna Niguel, when they were building the "last" shipment of (50), to Azland. GM,Buick and Olds, did some real odd-ball motors/parts for the Indy efforts. Unless you're a quite skilled corner burner/etc., you may find some challenges with Hilborns, on the street,(loading-up on low speeds). Story I was told, was use a excess fuel return tank, clos as possible to engine bay, (reduce load-up). Looks like a handful and fun. Good Luck, roverman.
Young olds
roger parkey
(10 posts)
05/02/2018 07:07PM
Re: New guy
Posted by: Young olds
Date: May 31, 2018 09:29PM
Is there a timing belt set up available for these engines( instead of a chain)?
Young olds
roger parkey
(10 posts)
05/02/2018 07:07PM
Re: New guy
Date: June 17, 2018 06:29PM
Had the engine running today, plan was to get it warm and full of water so I can set the fan controller. It was going well at first, nice oil pressure, steady idle, etc. then I noticed I was putting more water in then the engine should hold. Checked the oil and there is water in it, hopefully I shut it off before any bearing damage but Iím wondering if I have bad head gasket or something else. The block had a crack on the outside that leaked water, wondering if there is a crack inside.
Young olds
roger parkey
(10 posts)
05/02/2018 07:07PM
Re: New guy
Date: June 18, 2018 12:55AM
I picked up a rover 4.2 hoping to only use the shortblock. Will all the parts from my 3.5 bolt on? I know a ton of parts interchange but am unsure about the flywheel. I literally want to only use the bare block and rotating assembly and swap the rest from my 215.
Edited 1 time(s). Last edit at 06/18/2018 01:25AM by Young olds.
(3418 posts)
79 MGB, Buick 215
Re: New guy
Date: June 18, 2018 10:33AM
Like a Jessel Belt Drive? They are quite pricey. Doubt they are available for the 215.
Young olds
roger parkey
(10 posts)
05/02/2018 07:07PM
Re: New guy
Date: June 20, 2018 02:11PM
Yes like Jessel, or any other manufacturer.
I did some searching but I couldnít find the answer. Wondering what the piston dish volume is on the 4.2 motors?
