Goto Page: Previous1234Next
Current Page: 2 of 4
Re: New guy
Date: May 16, 2018 07:39PM
I suspect your Hilborn "butterflys", measure 1.8" dia. ? If so, same as mine. Mine has Hilborn pump and water pump driven, direct by cam. I was at Hilborn, in Laguna Niguel, when they were building the "last" shipment of (50), to Azland. GM,Buick and Olds, did some real odd-ball motors/parts for the Indy efforts. Unless you're a quite skilled corner burner/etc., you may find some challenges with Hilborns, on the street,(loading-up on low speeds). Story I was told, was use a excess fuel return tank, clos as possible to engine bay, (reduce load-up). Looks like a handful and fun. Good Luck, roverman.
Young olds
roger parkey
Washington state
(95 posts)
05/02/2018 07:07PM
Opel 1900 sport coupe 1975 Oldsmobile 215
Re: New guy
Posted by: Young olds
Date: May 31, 2018 09:29PM
Is there a timing belt set up available for these engines( instead of a chain)?
Young olds
roger parkey
Washington state
(95 posts)
05/02/2018 07:07PM
Re: New guy
Date: June 17, 2018 06:29PM
Had the engine running today, plan was to get it warm and full of water so I can set the fan controller. It was going well at first, nice oil pressure, steady idle, etc. then I noticed I was putting more water in then the engine should hold. Checked the oil and there is water in it, hopefully I shut it off before any bearing damage but I’m wondering if I have bad head gasket or something else. The block had a crack on the outside that leaked water, wondering if there is a crack inside.
Young olds
roger parkey
Washington state
(95 posts)
05/02/2018 07:07PM
Re: New guy
Date: June 18, 2018 12:55AM
I picked up a rover 4.2 hoping to only use the shortblock. Will all the parts from my 3.5 bolt on? I know a ton of parts interchange but am unsure about the flywheel. I literally want to only use the bare block and rotating assembly and swap the rest from my 215.
Edited 1 time(s). Last edit at 06/18/2018 01:25AM by Young olds.
(4615 posts)
Re: New guy
Date: June 18, 2018 10:33AM
Like a Jessel Belt Drive? They are quite pricey. Doubt they are available for the 215.
Young olds
roger parkey
Washington state
(95 posts)
05/02/2018 07:07PM
Re: New guy
Date: June 20, 2018 02:11PM
Yes like Jessel, or any other manufacturer.
I did some searching but I couldn’t find the answer. Wondering what the piston dish volume is on the 4.2 motors?
Young olds
roger parkey
Washington state
(95 posts)
05/02/2018 07:07PM
Re: New guy
Date: July 23, 2018 03:47PM
Bit of an update. After about 7 months I was in a position to pull my engine. I had found that water was getting into the engine from the timing cover behind the water pump. I purchased another timing cover and sold the rover in favor of keeping my 3.5 olds. Since the engine has been out I have been able to finish my engine bay, suspension( working on finishing the front brake upgrade) and finishing up on the tranny tunnel. As for the engine I tore it down to inspect after the water in oil incident, ended up going with new bearings but the cam checked fine. Finished my headers and wrapped them as well as a few other things including cosmetics. Hoping to have a drivable car in the next month or two.
Edited 1 time(s). Last edit at 04/24/2019 11:23PM by Young olds.
Young olds
roger parkey
Washington state
(95 posts)
05/02/2018 07:07PM
Re: New guy
Date: April 24, 2019 11:29PM
go Here for pictures [grassrootsmotorsports.com] I believe I will have it driving here in a month or so
Edited 1 time(s). Last edit at 04/30/2019 11:53AM by Young olds.
Sidecardoug
Doug Rowe
Northern Nevada
(51 posts)
07/04/2012 05:09PM
1969 TR-6 Ford 302
Re: New guy - Mickey Thompson
Posted by: Sidecardoug
Date: May 07, 2019 08:35PM
Roger,
Mickey Thompson was involved with the Harvey Aluminum Specials that ran Indianapolis in 1962
with Buick 215 engines - ( Dan Gurney's first Indy 500 - broken transaxle after 92 laps.) Your front cover may have come from some of his efforts to make the engine competitive in that arena - He claimed 330 hp on straight alcohol from a 255 cu in version of the Buick 215.
Young olds
roger parkey
Washington state
(95 posts)
05/02/2018 07:07PM
Re: New guy
Date: May 09, 2019 08:57PM
Wondering if anyone can tell me which port is oil out and which one is in in this remote filter adapter?
Young olds
roger parkey
Washington state
(95 posts)
05/02/2018 07:07PM
Re: New guy
Date: May 11, 2019 09:58AM
I figured it out
Young olds
roger parkey
Washington state
(95 posts)
05/02/2018 07:07PM
Re: New guy
Date: October 24, 2019 03:23PM
Looking to put new springs in my olds 215 I am freshening up to replace the current engine. Appears to have factory beehives, I need something that will handle 7000rpm.
minorv8
Jukka Harkola
(271 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Re: New guy
Posted by: minorv8
Date: October 24, 2019 11:29PM
If they really are beehives I very much doubt that they are factory items. They hardly existed in the 60's.
(2631 posts)
Re: New guy
Date: October 25, 2019 02:11AM
Olds were the first with the beehive springs in the 50s I believe. Pic of stock 215 Olds beehive valve spring:
Edited 1 time(s). Last edit at 10/25/2019 02:15AM by mgb260.
minorv8
Jukka Harkola
(271 posts)
04/08/2009 06:50AM
Re: New guy
Posted by: minorv8
Date: October 25, 2019 02:49AM
Well live and learn !
(6569 posts)
Re: New guy
Date: October 25, 2019 03:31PM
Yep, standard equipment in the 215. Nobody quite knew what to make of it.
Re: New guy
Date: October 30, 2019 07:31PM
They also came in 394 Olds, used on 215's for more pressure.
Young olds
roger parkey
Washington state
(95 posts)
05/02/2018 07:07PM
Re: New guy
Date: November 01, 2019 11:58AM
Do 394 springs work with stock retainer?
Re: New guy
Date: November 01, 2019 03:03PM
As I recall- yes. Your results may vary. Com Cams and Pacalloy have MANY different beehives.
(4615 posts)
Re: New guy
Date: November 01, 2019 06:24PM
I used a set from Comp Cams around 1990 for my Camaro. They called them conical valve springs back then.
