dlwharleyman
David Winn
(2 posts)
11/20/2017 10:44PM
Suggested gears for a ford 9 inch 3.55 in a 1974 Jensen Healey
Posted by: dlwharleyman
Date: May 25, 2018 11:48AM
My 74 Jensen Healey has a 1988 TPI (tuned port injection) 350 and a 700R4 automatic transmission, with a Ford 9 inch rear end with 3.55 gears. The rear tires are P205/60 R14 and look to be around 23" tall. The TPI 350 has a tons of low end torque. The previous owner used to drag race it and won some races. Needless to say, with the high torque and 3.55 gears, it takes very little gas for the tires to spin. Feels like I can hit the gas at 50 to 60 and have tire spin. Looking at putting lower gears in to make more highway friendly, but would still like some good torque for in town and mountain driving. Recommendations?
Jim Stabe
Jim Stabe
San Diego, Ca
(717 posts)
02/28/2009 10:01AM
Re: Suggested gears for a ford 9 inch 3.55 in a 1974 Jensen Healey
Posted by: Jim Stabe
Date: May 25, 2018 12:25PM
Those engines are stump pullers especially with an automatic. I would try to get a larger tire on the car for better traction as well as lower cruising rpm. With OD you won't need a super tall gear, maybe a 3.23 or so. Try to get the rpm at 70 mph under 2000, that seems to be a sweet spot for mileage.
(2977 posts)
Date: May 30, 2018 01:52PM
Got posi ? With the Huffaker rear glass fenders you get 12" wide wheelwell,(move shock). LT1 is all iron ? If so, around 60% +/- on front, weight bias ? Your size tires pretty hopeless for stoplight grandprix... Drag shocks on the front = bumpy street ride. Maybe finesse the instant center of rear suspension ? You could try some sticky slicks, to push that smile further back on your face ? Good Luck, art.
