(4619 posts)
Powerblast Plate for improved atomization
Date: July 16, 2018 02:38PM
I don't know if it really does much,but....
What say ye?
[www.thompsonperformance.com]
kstevusa
kelly stevenson
Southern Middle Tennessee
(986 posts)
10/25/2007 09:37AM
Re: Powerblast Plate for improved atomization
Posted by: kstevusa
Date: July 16, 2018 02:58PM
Strange looking contraption. Does it install in the Plenum or onto an injector? :-)
(4619 posts)
Date: July 16, 2018 03:37PM
It's for a carb, Kelly. Little piece of metal that blocks the squirter shot. So, instead of a stream it changes it to more of a fan shaped spray. I have my doubts, but for $40, may try one on the front of my carb.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: July 16, 2018 05:24PM
Interesting product.....functionally, makes sense for better fuel atomization and throttle response.
Would be nice to get some user feedback before investing $80.......are you listening, Carl ?
(4619 posts)
Date: July 16, 2018 06:09PM
Just $40 for the front half of the carb. A guy on Facebook bought into it. I think it is probably much ado about nothing.
As you know, the squirter nozzleis just where the fuel comes from when the accelerator pump is activated. It is a temporary fuel supply, so how does it make that horsepower on the graph?
Might aid a stumble, bog, hesitation issue, maybe?
ex-tyke
Graham Creswick
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: July 16, 2018 11:19PM
The obvious question is why Edelbrock, Holley, et al, didn't design a nozzle atomization product for their carbs - seems too simple and logical to overlook.
(4619 posts)
Date: July 17, 2018 11:09AM
I agree, Graham. Seems they would have done it, except they haven't changed those carb designs in 50 years.
(6576 posts)
Date: July 17, 2018 04:13PM
Typically your pump shot is aimed at the edge of the annular boosters and breaks up when it hits there.
88v8
Ivor Duarte
Gloucestershire UK
(1059 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: July 19, 2018 04:26AM
The theory is good.
Atomise the fuel.
Used to be a doohikus that you could add to an SU to scrape the liquid boundary layer of fuel off the intake walls, it was called the Mangoletsi Manifold Modifier.
[www.mangoletsimanifolds.com]
I had a pair on my 215.
No idea whether they worked!
Ivor
joe_padavano
Joseph Padavano
Northern Virginia
(160 posts)
02/15/2010 03:49PM
Posted by: joe_padavano
Date: July 19, 2018 12:07PM
The accelerator pump stream is atomized by aerodynamic shearing forces when it hits the airstream in the venturi. If any of these snake oil products worked half as well as claimed, they'd already be incorporated in the product design from the original manufacturer. The one I find most amusing is the throttle body spacer plates for port EFI motors. If an extra 3/4" of runner length made such a big performance difference, why wouldn't the intake manufacturer simply cast the runners that much longer? Sorry, these products peg the BS meter.
(6576 posts)
Date: July 19, 2018 02:34PM
On SOME engines a 1 or 2" riser under the carb does give a performance benefit under some circumstances. Certainly not all.
