Young olds
roger parkey
Washington state
(27 posts)
05/02/2018 07:07PM
Opel 1900 sport coupe 1975 Oldsmobile 215
I need help deciding what to build.
Posted by: Young olds
Date: August 30, 2018 01:13PM
With my current engine in the Opel being bad Iíve been trying to decide what to build as a replacement. I have a buick 215, .030 over, clean block probably would be fine with just a fresh hone and new rings. Seems like my cheapest and easiest option but the pistons are dished and would result in low compression. I also have a 4.2 with a pitted cylinder wall, probably needs at least .020 over to clean up. What I really wanted to do was use the 4.2 block with my stroker crank(3.315Ē) and 305 pistons to build a 290 but I donít want to get into custom length rods or pistons. Iím not hung up on getting the most cubic inches I just want a strong runner that uses off the shelve parts.
Young olds
roger parkey
Washington state
(27 posts)
05/02/2018 07:07PM
Re: I need help deciding what to build.
Date: August 30, 2018 09:57PM
Btw this is going to be for my road race/autocross opel.
Young olds
roger parkey
Washington state
(27 posts)
05/02/2018 07:07PM
Date: September 03, 2018 11:28PM
Does the ati damper work with a wet sump system? In the notes it says for dry sumo systems but itís the only aftermarket damper I can find
MGB SS
Joe Schafer
Central Michigan
(149 posts)
10/23/2007 06:46AM
1971 Mgb 1991 5.0 Ford
Posted by: MGB SS
Date: September 12, 2018 09:04PM
Get different pistons for the 215 going to be apart to re-ring anyway, just a thought
(5735 posts)
Date: September 13, 2018 02:50PM
I think if a damper is made to work with a dry sump it should work equally well with a wet sump. Can't imagine any reason why it wouldn't. But to be safe, have the rotating assembly balanced.
Young olds
roger parkey
Washington state
(27 posts)
05/02/2018 07:07PM
Date: September 14, 2018 12:41PM
Thatís what I was thinking but wasnít confident
(5735 posts)
Date: September 14, 2018 01:52PM
Also check with "Damper Dudes" for rebuilt units.
Young olds
roger parkey
Washington state
(27 posts)
05/02/2018 07:07PM
Date: September 24, 2018 12:02AM
I believe I found and fixed my issue with getting water in the current engine, if it works out I wonít be building a new one for a while.
