murray.arnold
murray forbes-arnold
croatia
(16 posts)
09/13/2018 01:25AM
1973 MGB GT ROVER 3.5 V8
HOLLEY CARB CONVERSION
Posted by: murray.arnold
Date: September 19, 2018 12:15AM
Good day all. I have already posted a message over the last week regarding a carb conversion to my V8 MGB. So with the input of a few of you, including useful links, I have now worked out a few things. Firstly my carb (Holley 4 barrel 8007)has been installed back to front. No wonder I can do 100mph in reverse, ha. Anyway, this is easily rectified. I also now know that my 3 speed box is a Borg Warner BW65. I now have a good idea as to what I need to do to address the engines breathing issues.
I have now also purchased a new BW65 kick down cable, new oil strainer and gaskets and oil. Only one thing is left that I need help with. Thats the kick down linkage for the carb. I have emailed reel steel twice and they have not responded. Also Holley said they don't deal with European cars. Which I think was very unhelpful TBH.
Can some kind soul help me sort out the linkage issue. Oh and here's a thing. What if after all this the kick down doesn't work. What if after all this time its a gearbox issue. And if so, would there be a common fault that's a simple fix.
Many thanks guys for all your time.
PS. I am in Kuwait and the cars in Croatia, which makes fault finding not exactly easy.
(6590 posts)
Re: HOLLEY CARB CONVERSION
Date: September 19, 2018 01:34AM
Might find something here"
[www.holley.com]
The arm should pull the cable when the throttle opens of course, so it is attached below the throttle shaft.
murray.arnold
croatia
(16 posts)
09/13/2018 01:25AM
Date: September 19, 2018 03:47AM
Hi Jim. I have no doubt I will end up having to modify something. How much travel is expected to operate the kickdown. 1 inch or less? I see many different attachments for the kick down. I am sure a bit of engineering will resolve it.
(6590 posts)
Date: September 19, 2018 12:04PM
Once you have the pan off measure the travel of the piston and match that at the carb. Make your housing mount adjustable so you can change the shift point.
88v8
Ivor Duarte
Gloucestershire UK
(1059 posts)
02/11/2010 04:29AM
Posted by: 88v8
Date: September 19, 2018 04:06PM
Kuwait? Croatia?? Caramba.
I just posted a linkage here [forum.britishv8.org]
Real Steel aren't very good at computers. You might do better to ring them.
Ivor
murray.arnold
croatia
(16 posts)
09/13/2018 01:25AM
Date: September 20, 2018 01:17AM
thanks Ivor. Got your message and replied.
