minorv8
Jukka Harkola
(271 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Piston ring land question
Posted by: minorv8
Date: April 16, 2019 06:44AM
I hit a slight problem when doing a dummy build of a stroker 4.6. The pistons protrude about 1/16" from the deck. That is basically an easy fix, put the pistons in a lathe and cut them. I do know that I have had the decks of the block machined in the past but donīt know if that was the first time or if it has been machined before.
But, these are forged stroker pistons with roughly a 1,2" compression height and ring land from crown to 1st ring is about 0,21". So not exactly excessive amount of material to machine.
What do you consider a safe ring land dimension given that it is a N/A engine ? Finding another 4.6 block is not the easiest solution.
(6586 posts)
Re: Piston ring land question
Date: April 16, 2019 11:17AM
The risk with any piston is too much heat on the top ring land, particularly adjacent to the exhaust valve. .210" isn't much but these are forged pistons right? So that is probably OK. Cutting it down to .150" probably isn't though, not if this engine is ever going to be run hard. Just my opinion, but if it fails, at best you'll have increased blowby and the consequences could be much worse.
(4627 posts)
Date: April 16, 2019 04:18PM
That top ring will need a bigger end gap.
