66V8
Ed Stubbs
(1 posts)
06/28/2016 04:15PM
Alternator Mounting Bracket
Posted by: 66V8
Date: May 01, 2019 04:15PM
Where can I get a mounting bracket for my alternator? I want to mount it on the drivers side of a left hand drive car. I can't find one here in the UK. Bracket is for a Rover V8 3.5 sd1 engine.
Ed
Edited 2 time(s). Last edit at 05/22/2025 07:15PM by MGBV8.
mstemp
Mike Stemp
Calgary, Canada
(224 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Re: Alternator Mounting Bracket
Posted by: mstemp
Date: May 01, 2019 05:30PM
What motor?
If Rover you can get it from D&D.
[aluminumv8.com]
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: May 01, 2019 05:35PM
Do we assume that you have the ubiquitous Rover engine (3.5, 3.9, 4.0, 4.2, 4.6).?....or some other engine?
First place I'd check are the conversion/installations in the "photo galleries" at the top of the page for left hand mount alternators...find an installation that appeals and perhaps 'PM' the owner for particulars.
As a last resort, barring any off-shelf bracket(s) availability, it's possible to fabricate a mounting system without too much difficulty.
ex-tyke
Graham Creswick
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: May 01, 2019 05:38PM
Adding to Mike's post, here's the D&D part info.
7780-14-RL Alternator Bracket – Rover cylinder head, left side, V-Belt drive, for MG’s without air conditioning.
v8mgb
Jim Miller
(166 posts)
01/01/2008 11:38AM
78 MGB Buick 215
Posted by: v8mgb
Date: May 22, 2025 04:49PM
I have modeled a drivers side alternator bracket for the Rover HRC 2210 heads. It may fit other Rover heads I sent the step file to Xometry.com where the part was CNC machined using 1018 steel. I purchase Mild Steel Spacer Bushing 3/4" OD x 1/2" ID off eBay then cut and filed it to the length. I also have the bolt holes located for the mounting holes on both sides to make your own custom bracket is anyone is interested. I am using a Delco CS130 for a 1989-1992 Buick Century. The bushing is 1.856" long. There is also a support bracket between a water pump bolt and the post on the alternator bracket.
Here is the link to the STEP file. anyone machining the part will need this
[drive.google.com]
Here is the link to the DWG wile if toy want to modify the design
[drive.google.com]
[attachment 23761 AlternatorBracketWithPost.jpg]
Edited 4 time(s). Last edit at 05/28/2025 12:07PM by v8mgb.
