EdWimble
Ed Wimble
(1 posts)
06/20/2019 01:26PM
Need a stock Olds' 215 oil pump/filter mounting
Posted by: EdWimble
Date: June 20, 2019 05:46PM
Rebuilding my Olds' 215 but cannot locate the original oil pump cover/filter mount. It has to be the original Olds' part with the parallel mounting and filter faces so the filter axis is parallel with the pump in order to fit in the available space.
The Rover mounts the filter facing forward and angled roughly 45° downwards but it interferes with the lower radiator hose...no good.
The Buick V6 mounts the filter parallel with the ground pointing diagonally off the front lower corner & touches the frame rail....again, no good.
I'm not sure about the Buick 215, it could be the same as Rover which won't work, or, the same as the Olds' with the parallel mounting faces, which will work (any advice will be much appreciated).
Can anybody help with this guys ? I'm sure someone must have an Olds' with a non standard filter mount or remote, with one of these going spare & collecting dust....just like mine is somewhere !
Also, I have extra Olds heads but without the rocker arms, shafts & posts.
Is there a source for these, does anyone know ?
Many thanks guys, Ed.
Edited 1 time(s). Last edit at 06/20/2019 06:10PM by EdWimble.
Blown v8
Bryan Phipps
(72 posts)
03/10/2013 04:52PM
Re: Need a stock Olds' 215 oil pump/filter mounting
Posted by: Blown v8
Date: June 23, 2019 12:01PM
I used one of these
I got it from Speedway motors,part no.M-6880-A50 all correct threads, swivels so you can put it for most clearance
Edited 1 time(s). Last edit at 06/23/2019 12:02PM by Blown v8.
(4628 posts)
Date: June 23, 2019 12:35PM
Does that work with the Buick/Olds/Rover V8s? Says it's for Ford.
I have a swivel oil filter mount on my Buick 215. Bought it from Dan LaGrou 18 years ago.
Blown v8
Bryan Phipps
(72 posts)
03/10/2013 04:52PM
Posted by: Blown v8
Date: June 23, 2019 01:13PM
Check the threads,I’m going to guess yes
