Bland
Tim Bland
Oregon
(36 posts)
01/22/2017 11:15PM
1980 Triumph TR8 Rover 3.5
ARP Main Studs
Posted by: Bland
Date: September 03, 2019 03:23PM
I have two sets of ARP main studs for a 3.5. Does anyone know if these studs will work with a 4.6?
Tim
(4628 posts)
Re: ARP Main Studs
Date: September 03, 2019 05:46PM
Should. Do you have a part # to verify?
(2633 posts)
Re: ARP Main Studs
Date: September 03, 2019 08:11PM
I don't know for sure if they would work but the main caps are different with crossbolts. Really not necessary. I would use shims for the crossbolts after the mains are torqued first.
minorv8
Jukka Harkola
(271 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Re: ARP Main Studs
Posted by: minorv8
Date: September 04, 2019 12:15AM
Yes, I have fitted ARP main bearing studs to a 4.6 block. Watch out the torque setting though. ARP recommended setting is pretty excessive. The crank in my block was locked solid before the ARP value was reached. If you use them I recommend that you check the bearing bores, you may need to line hone the main bearing bores.
MG four six eight
Bill Jacobson
Wa state
(326 posts)
10/23/2007 02:15AM
Re: ARP Main Studs
Posted by: MG four six eight
Date: September 04, 2019 01:15AM
X2 with what minorv8 stated. I have them in my supercharged 215 and my machine shop highly recommended line honing when installing main studs, due to the increased clamping load.
It's not a bad idea to hone the rods also if you are using ARP rod bolts, as this will give you more consistent bearing clearances.
Bill
(2633 posts)
Re: ARP Main Studs
Date: September 04, 2019 10:01AM
Definitely agree with Bill on ARP studs for the 215/3.5. The original poster was wondering if the ARP studs for the 215 would fit the later crossbolt block or if they were different.
Bland
Tim Bland
Oregon
(36 posts)
01/22/2017 11:15PM
Re: ARP Main Studs
Posted by: Bland
Date: September 04, 2019 08:50PM
I have two sets of part number 124-5401.
Tim
(4628 posts)
Re: ARP Main Studs
Date: September 05, 2019 11:58AM
124-5401 is for teh Buick 215. ARP web site shows 157-5401 for the 4.0 & 4.6 The kit comes with the main studs & the side bolts.
[arp-bolts.com]
minorv8
Jukka Harkola
(271 posts)
04/08/2009 06:50AM
Re: ARP Main Studs
Posted by: minorv8
Date: September 09, 2019 04:42AM
Here is a 4.6 block with 3.5 litre ARP studs.
