Clutch Pressure plate for Buick 215 V8
I have been trying to find a pressure plate for my 1961 Buick 215 V8, stock light flywheel. I would like to find a stock one so no mods are required to the fly wheel. I’m adapting a T5 Ford WC, 1352-169, and will use a clutch plate with a 10 spline, 1 1/16” center for the T5.
Can anyone point me in the right direction? Thanks, Virg |
mgb260 Jim Nichols Sequim,WA (2632 posts) Registered: 02/29/2008 08:29PM Main British Car: 1973 MGB roadster 260 Ford V8 |
Re: Clutch Pressure plate for Buick 215 V8
The GM late (say for a Camaro) V6 pressure plate and clutch also works. This gives a light pedal and still handles the HP. I believe a may have one in my stash. PM me if you are interested and I will seek it out and send you pictures. It is new and complete.
James, He has a Ford T5. Clutch splines are different. The Ford pressure plate I mentioned bolts right up. The Camaro pressure plate would have to have the flywheel redrilled to fit.
Edited 1 time(s). Last edit at 11/22/2019 12:39AM by mgb260. |
