turbodave
dave cox
(196 posts)
04/30/2018 03:00PM
SD1
Failure of stock cast 3.9/4.0 pistons at higher RPM?
Posted by: turbodave
Date: December 30, 2019 09:17AM
AE Hepolite
HRC1828
22059
The "books" suggest that 6K rpm is all these are good for, with maybe an occasion blast up to 6500 rpm.
Has anyone taken these higher and suffered (or not) a failure?
I'm trying to decide if I should stick with them and pick a cam that maxes out at 6200rpm.
I've got solid adjustable rockers (and would therefor use a solid, not hydraulic cam) so the only limitation will be the factory pistons.
(6590 posts)
Re: Failure of stock cast 3.9/4.0 pistons at higher RPM?
Date: December 30, 2019 10:25AM
Not sure about the Hepolites, I regularly wound a 215 with the stock OEM high compression pistons to 7K and after 30-40K miles cracked the skirt of one of them.
