minorv8 Jukka Harkola (214 posts) Registered: 04/08/2009 06:50AM Main British Car: Morris Minor Rover V8 |
Coil packs under the intake manifold
I am (slowly) making a new plenum for my next engine. My current setup has the coil packs mounted on the firewall just behind the intake manifold. This is not perfect location, especially when I need to remove the engine. With the new intake there will be even less space. I have been thinking about mounting the coil packs underneath the plenum since there is plenty of space.
Now, the question is would there be any ill effects, e.g due to heat from the engine ? My engine room is crowded enough so finding a better location is a bit challenging. I'll upload some photos once I have them reduced in proper size. |
88v8 Ivor Duarte Gloucestershire UK (821 posts) Registered: 02/11/2010 04:29AM Main British Car: 1974 Land Rover Lightweight V8 |
Re: Coil packs under the intake manifold
The two prime causes of coil failure... vibration, heat.
Custom cars, with a clean engine bay, presumably mount them in the cabin. Use the space under the plenum for other purposes. [www.wikihow.com] Ivor |
This is what my plenum will look like. I am still thinking which throttle body to fit. I currently have a 75 mm Mustang throttle body (chinese knockoff) but its linkage does not fit my plenum design. I need to get creative with the thermostat housing as well. Here is a single coil pack stashed underneath the plenum for demostration purposes. This is a injection Mini coil, the Bosch coil packs I have are a touch smaller. TVR AJP V8 have the coil packs in the lifter valley and in a very tight space. I doubt that my setup would be that bad. Factory LS coils are mounted to the valve covers and they see a fair amount of heat and vibration too. |
BlownMGB-V8 Jim Blackwood 9406 Gunpowder Rd., Florence, KY 41042 (6000 posts) Registered: 10/23/2007 12:59PM Main British Car: 1971 MGB Blown,Injected,Intercooled Buick 340/AA80E/JagIRS |
Pretty big plenum. Will that cause any problems?
You should be able to get by with putting the coils there if you allow some airflow through the area I would think. Jim |
I’m thinking of putting mine on the block,under the headers, plenty of room,plenty of airflow, headers will be cam coated to help,
And it’ll keep the leads short, and clean looking. |
DiDueColpi Fred Key West coast - Canada (1267 posts) Registered: 05/14/2010 03:06AM Main British Car: What if the Hokey Pokey really is what it's all about? |
I don't see any problems with placing the coil packs under the plenum Jukka.
Almost every COP engine places their coils in the hottest place on earth and then covers them up with some pretty plastic to make sure that they are miserable. They seem to last just fine. Cheers Fred |
OK, thanks Fred. I just need to fabricate a bracket for the coil packs. There is a photo of my thermostat housing that I welded together from some scrap laying around. There are bungs for an EFi coolant temp sender and a mechanical temp gauge.
Edited 1 time(s). Last edit at 08/23/2020 05:27AM by minorv8. |
Bland Tim Bland Oregon (36 posts) Registered: 01/22/2017 11:15PM Main British Car: 1980 Triumph TR8 Rover 3.5 |
What ECU will you be running?. I need to build a thermostat housing similar to yours for my ITB manifold.
