Re: Jag IRS, Dana Unit Questions?
I'd no idea their life was so short.
And presumably the wear particles find their way into the bearings. A viscous lsd like the Nissan R200 that can be fitted to the TR6, seems a better idea. Pity they're not more available. Ivor |
"And presumably the wear particles find their way into the bearings."
That would mainly just be the clutch friction material. |
The wear particles don't seem to be a problem, apparently they are small enough and fall to the bottom or get minced by the gears. Personally I like the Power-Lok instead for a number of reasons. Having all steel clutches, they last longer. Having ramps on the cross pin ends they are less dependent on the cup springs to apply, they are easier to assemble, and have twice the number of spider gears. But they do wear also, just not as fast. They can also be heavily preloaded if desired. Of the entire spectrum of less expensive posi units they are probably the best, although some drivers would prefer the Detroit Locker. Moving up in price of course you have your gear type, viscous, and of course on-demand electric or air lockers. The gear type were once considered THE thing but that was before everyone realized that they can't ever transfer 100% torque to the driving wheel. Every design has limitations, you just have to pick the ones you can live with and afford. I'm not sure exactly what the limitations of the viscous ones are, not having driven one, but I suspect heat, and less that 100% load transfer.
Now having rebuilt this, I can see its not such a big deal to leave the axle in the car & pop out the carrier to replace the plates when its time.
This Dana diff has a 2.88:1 ratio, I do have a salsbury Power Lock unit with a 3.7:1 ratio in as new condition in my spares stash, maybe use that if this 2.88 is not a good match later on. |
May want to look for a set of gears around 3.31, I think that will fit the 3.71 carrier but check. Look for a set of original Dana gears as they are harder and will wear longer.
Tim, I'm not sure which means probably not. I went to some trouble to be able to make the half-shafts the limiting factor rather than the upright bells and to preserve maximum suspension travel. It probably sits about at stock height or maybe a little lower but of course it's also 6" wider.
Jim. |
There is some info in the 340 thread and the roadmaster thread though.
I could submit an updated HIWD but would it ever get posted? Jim |
Jim, Ive seen MG's with jag axles but never looked too close, are you saying with keeping the stock track I'll have to limit the suspension movement?
Quote:I submitted updated HIWD info to Curtis over 2 years ago and still no activity..... suppose that PACCAR is keeping him pretty busy these days. |
