300" Buick Main Bearings ?
A.I.R., 4.0-4.6L RV8 is 2.450" dia. ? On this forged crank, I want to start with 2.500". Where to buy HiPerf. bearings ?
Thanks, Art. |
minorv8 Jukka Harkola (268 posts) Registered: 04/08/2009 06:50AM Main British Car: Morris Minor Rover V8 |
Re: 300" Buick Main Bearings ?
Assuming you have 4.0/4.6 block and you need bearings for that application check out King Bearings.
www.king-catalog.com/Catalog/Engine/10079073 (4.6 litre) If you have a 300 block and want to use 4.6 bearings the link includes dimensions for mains bore size. Width of the bearings may be an issue, especially the flanged shell. Edited 1 time(s). Last edit at 04/19/2021 01:30AM by minorv8. |
Thanks Jukka, Even more, out-there. I'm machining an SBF, 4340 raw forging crank, to fit RV8.
Art. |
