phongshader
Justin Brown
Ca
(63 posts)
02/19/2010 04:03PM
Locost Lotus 7 2.3 Duratec
Rover/Buick lifters in Olds Block?
Posted by: phongshader
Date: June 12, 2021 12:01PM
Will Rover/Buick lifters in fit/work in an Olds block?
(2463 posts)
Re: Rover/Buick lifters in Olds Block?
Date: June 12, 2021 01:14PM
Should be the same. Always use new lifters with a new cam and same places they were on a used cam.
phongshader
Justin Brown
Ca
(63 posts)
02/19/2010 04:03PM
Date: June 14, 2021 11:48AM
how about Buick 350 lifters?
(2463 posts)
Date: June 14, 2021 01:40PM
That is what I use for pushrod oiling.
phongshader
Justin Brown
Ca
(63 posts)
02/19/2010 04:03PM
Date: June 15, 2021 02:46PM
If I'm running stock oiling will the 350 lifters be compatible? I'm going to be running a crower 50233 cam
Product ID: TA_1405J
JOHNSON HYD. LIFTER '70/UP
350, 455 `70 & later (Johnson lifter)
Price: $135.00
or
Product ID: TA_1406
HYDRAULIC LIFTERS PRE 1970
Hydraulic Lifters that fit ALL V8 1956-1969 Engines
Price: $280.00
Edited 1 time(s). Last edit at 06/15/2021 04:32PM by phongshader.
(6469 posts)
Date: June 15, 2021 07:17PM
Certain SBC lifters are also compatible.
phongshader
Justin Brown
Ca
(63 posts)
02/19/2010 04:03PM
Date: June 16, 2021 02:07PM
Would stock lifters work with a spicy cam or would I need to go with something that won't pump up? I'm not going over 6k rpm. I've always used anti pump lifters but they are hard to get at the moment. Something like these? [www.summitracing.com]
Edited 1 time(s). Last edit at 06/16/2021 02:08PM by phongshader.
minorv8
Jukka Harkola
(269 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Posted by: minorv8
Date: June 17, 2021 05:16AM
I have used Crane 99284-16 and Comp 869-16 hydraulic lifters in my Rover engines.
(6469 posts)
Date: June 17, 2021 11:28AM
Anti pump up lifters are just leaky lifters. Prone to tap. If you want a 6k or higher redline it's best to fit heavier valve springs.
