Rover v8 3.9l into triumph stag 1971
Re: Rover v8 3.9l into triumph stag 1971
Are you certain those are installed correctly? Looks as though the flange with two holes (underneath in the center) might bolt to the block with the unused (in the photo) hole bolted to frame. And swap sides
Have you referenced the examples in the "Photo Gallery" - maybe PM the owners for some direction.
[www.britishv8.org] [www.britishv8.org] |
