donfaber Don Faber Terra Alta WV (120 posts) Registered: 10/31/2007 10:53PM Main British Car: 1979 MGB 3.9L Rover V8 |
Re: Crankcase ventilation Rover 3.9L V8 w/ Edelbrock carb
Carl - I'm only installing a flame trap on left side - pcv already installed on right side. Seems to be the consensus?
Don |
Right. I got hung up on Fred's suggestion of a crankcase depression regulator & forgot that you were only looking for a flame trap. :)
I am intrigued by this CDR. Not sure I really understand the difference between it & a PCV. I have read that a CDR is a essentially a PCV for diesel engines. It functions in the opposite manner in regards to vacuum. |
Part of a stainless steel pot scrubber pad makes a pretty good flame trap. You can use it in any suitable enclosure. As an example, I have about half of a pad strung out and drawn into 1" diameter length of silicon hose which runs from my mechanical fuel pump block off plate up to the inlet of my Enderlie style intake scoop. You can probably see it in my avatar, the hose is blue which contrasts with literally everything else on the car. Rover uses a canister on the valve cover similarly filled.
I'd like to see an explanation of that regulator compared to the TR4 pcv. Is there a difference in the way they work? Jim |
It also has one inlet and one outlet.
The "TR4" pcv is essentially the same as the cdr system.
It's biggest flaw was that it was prone to ingesting oil due to the limited drain back from the cylinder head. (try filling the TR engine with oil. The valve cover fills almost immediately) It also doesn't have big enough plumbing, probably due to the drain back issue. The rear crank scroll seal was also a miserable thing that allowed air (and contaminants) to enter the engine, defeating the pressure drop and exacerbating the drain problems with the upper engine. It's biggest problem however, was that it was different. Most didn't understand how it was supposed to work and hobbled it with catch cans, road draft tubes, crankcase vents, etc. They then removed the valve because the engine wouldn't idle properly. It gained an undeserved reputation as a bad design. That problem seems to continue to this day. With almost any engine or unconventional system falling into disfavor. Many "fixes" for engine breathing issues still recommend catch cans and open breathing mods. None of that is required with a properly designed and operating system. |
Gswest236 Scott West Seabeck, Washington (172 posts) Registered: 07/14/2021 09:13PM Main British Car: 1974.5 MGBGT V8 Olds 215 Stroked to 266 |
I had this exact issue with my GT V8. Oil pumping out every possible seal. After I got the CDR installed, no oil on the floor after a spirited drive. And no oil on the Offy valve covers around the oil fill openings. Best $50 I’ve spent yet (CDR part exactly as shown in this forum above). Look on ebay or Amazon etc.
The crankcase needs an air inlet otherwise it can't be scavenged. So that's whichever rocker box you currently have as the inlet, which may have a little filter on or not.
What you're scavenging is the crankcase, and both rocker boxes are connected to the crankcase so only one of them needs to be connected to the o'ringed side.. For the CDR, I would use the connection point to the manifold rather than the PCV port. My own RV8 is vented from the original flame trap to the underside of the air filter, no PCV. Mind you, it's not parked over a clean surface so I couldn't tell you whether there are any leaks, but the inside of the rocker boxes is nice and clean. Ivor |
With oil leaks the problem is not pcv but blowby. Blowby is the thing that creates positive crankcase pressure and it will always exceed the capacity of any pcv system under full throttle. The more power the engine produces, the more blowby it makes. So the answer is a means of routing the blowby to the intake.
Ever wonder why drag race engines used as many as 4 breathers on the valve covers? To vent the blowby, they certainly weren't for looks. If they weren't needed they wouldn't be there. That should give you a small hint of what you are dealing with. And the more worn the engine is, the more the blowby. Here's a tip. You use a block-off plate for the mechanical fuel pump right? So drill and tap that plate for the largest pipe thread you can, install an elbow to point it up, and run a big hose to the air intake. Stuff the hose with a scrubber pad for a flame arrester and then plumb the pcv system however you like, making sure there is some sort of a restriction there. A pcv valve is a good idea because it allows full flow at low pressure conditions (WOT) to supplement the blowby tube. Jim |
Thanks Jim, I will definitely try this venting solution from the fuel pump blank off plate. Question for you, do you suggest running this to the air filter inlet? Then a standard PVC system and breather on the valve covers? So basically the PVC system works as intended but blow by pressure is vented to the intake as needed?
That is correct Dave. The only difference between this and a factory setup is that the factory connected the breather line to the opposite valve cover. Aside from increasing the line size.
