Goto Page: 12Next
Current Page: 1 of 2
donfaber
Don Faber
Terra Alta WV
(120 posts)
10/31/2007 10:53PM
1979 MGB 3.9L Rover V8
Crankcase ventilation Rover 3.9L V8 w/ Edelbrock carb
Posted by: donfaber
Date: July 27, 2021 12:13PM
In a nutshell (I'm 66 and still learning) - for my rover V8 with Edelbrock carb.... PVC valve from one valve cover to base of Carb, vent line from other valve cover to air filter inlet on carb.
donfaber
Don Faber
Terra Alta WV
(120 posts)
10/31/2007 10:53PM
Re: Crankcase ventilation Rover 3.9L V8 w/ Edelbrock carb
Posted by: donfaber
Date: July 27, 2021 09:44PM
Is the setup I've described "correct?"
(1389 posts)
Date: July 27, 2021 10:00PM
Absolutely Don. It's the classic way to ventilate the engine. And it will work just fine. You will have to play around with PCV sizes to fine tune it, mostly to stabilize the idle.
The more modern set up is to use a constant depression regulator to provide a regulated pressure drop inside the engine. This is a little more complex to achieve but it virtually eliminates oil leaks. That's the downside as you no longer know if your British car has oil in it.
Live like you mean it.
donfaber
Don Faber
Terra Alta WV
(120 posts)
10/31/2007 10:53PM
Posted by: donfaber
Date: July 28, 2021 10:08AM
Thanks, Fred!
(6585 posts)
Date: July 28, 2021 02:52PM
Use the largest practical hose you can for the vent line. 3/4 is good and 1" isn't too big. 5/8" would be OK if these engines didn't have a reputation for blowby. Be sure there is a flame trap in that line.
(4626 posts)
Date: July 29, 2021 09:29AM
"The more modern set up is to use a constant depression regulator to provide a regulated pressure drop inside the engine. This is a little more complex to achieve but it virtually eliminates oil leaks. "
Would love to hear more about this, Fred. As Jim mentioned, these engines tend to be heavy breathers.
donfaber
Don Faber
Terra Alta WV
(120 posts)
10/31/2007 10:53PM
Posted by: donfaber
Date: July 29, 2021 12:45PM
Jim - I assume that's not the same as a breather - can you recommend a flame trap or supplier? Thanks
(1389 posts)
Date: July 29, 2021 01:13PM
Virtually all newer vehicles use some form of this breather system Carl.
It's essentially a large pressure regulator connected between the crankcase and the intake plenum.
It maintains a constant pressure drop differential in the crankcase of around 2 psi. No other vents or breathers are used.
It works very well. We see engines with several hundred thousand miles on them that are perfectly dry.
A good example is the Jag/Rover part AJ87773 to give you an idea.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: July 30, 2021 08:06AM
Here ya go, Carl!
(4626 posts)
Date: July 30, 2021 09:23AM
I need one!
donfaber
Don Faber
Terra Alta WV
(120 posts)
10/31/2007 10:53PM
Posted by: donfaber
Date: July 30, 2021 10:20AM
Let me know where u find it, Carl!
(6585 posts)
Date: July 30, 2021 10:22AM
Is that any different from the big metal one used on the TR4? So no fresh air inlet with those huh?
ex-tyke
Graham Creswick
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: July 30, 2021 11:59AM
Seems to be used on 2000 - 2009 vintage Jags.
Could spend $50+ for a new one, try the wrecking yards or steal one off Kelly's XK8 .
Edited 1 time(s). Last edit at 07/30/2021 12:00PM by ex-tyke.
(1389 posts)
Date: July 30, 2021 01:35PM
Nope no fresh air Jim just a light vacuum. The Oringed part goes to the valve cover and the barbed fitting goes straight into the intake manifold plenum. A silicone diaphram and spring regulate the pressure in the crankcase.
Try undoing the oil filler cap while the engine is running Graham. You'll see what I'm talking about.
(6585 posts)
Date: July 31, 2021 09:36AM
So... is that any different from the big metal one used on the 1966 TR4?
(4626 posts)
Date: July 31, 2021 09:42AM
Sounds like an oversize PCV.
donfaber
Don Faber
Terra Alta WV
(120 posts)
10/31/2007 10:53PM
Posted by: donfaber
Date: July 31, 2021 02:51PM
Found #379-580 - for 70-71 TR6 - Moss Motors
ex-tyke
Graham Creswick
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: July 31, 2021 03:36PM
A GM version of the crankcase regulator valve # 25097699
(4626 posts)
Date: August 01, 2021 10:06AM
"Found #379-580 - for 70-71 TR6 - Moss Motors"
Moss says that is a just flame trap, Don.
(6585 posts)
Date: August 01, 2021 11:25AM
Goto Page: 12Next
