motman nigel cooper hailsham uk (16 posts) Registered: 08/28/2011 04:50AM Main British Car: MG Roadster SBF347 |
e10
Hi, as the uk is now changing to e10 fuel, how will this affect my 302 mgb, am i correct in assuming the usa has had e10 for years and if so then most of you must be using e10,any problems,btw my car is fuel injected,pro flo 4
Spitfire 350 Phil McConnell Perrysburg, OH (Toledo area) (248 posts) Registered: 01/11/2010 09:19PM Main British Car: 74 Spitfire 350Chevy |
Re: e10
I'd be surprised if you could really tell the difference. I would suggest fuel stabilizer for storage times.
88v8 Ivor Duarte Gloucestershire UK (1008 posts) Registered: 02/11/2010 04:29AM Main British Car: 1974 Land Rover Lightweight V8 |
Re: e10
Your fuel hoses may need changing unless they are recent.
Likewise the diaphragm in your fuel pump if it has one. And the gaskets in your carb. I had to rebuild the Holley on my Rambler. The FBHVC has published some recent thoughts here [fbhvc.co.uk] which are worth reading. Inter alia, they say Ethanol contains approximately 35% oxygen by weight and will therefore result in fuel mixture enleanment when blended into petrol. Petrol containing 10% ethanol for example, would result in a mixture-leaning effect equivalent to approximately 2.6%, which may be felt as a power loss, driveability issues (hesitations, flat spots, stalling), but also could contribute to slightly hotter running. Adjusting mixture strength (enrichment) to counter this problem is advised to maintain performance, driveability and protect the engine from overheating and knock at high loads. Adjusting mixture strength is very easy on SUs of course, not so easy with fixed jets which generally don't have adjustable air bleeds for intermediate and high-speed. I always use Super grade which is and fttb will remain E5 or even E0. And I routinely use an additive, Castrol Valvemaster or the like which is anti-ethanol plus octane boost. My car has been sitting three months since I broke a bone, it now has half a tank of somewhat stale fuel. V8 Edited 1 time(s). Last edit at 08/19/2021 04:34AM by 88v8. |
Re: e10
The hoses are the largest worry IMO
The only fuel hose I use now is gates barricade. Not the cheapest - but a lot cheaper than the excess (deductable) on a claim... |
IaTR6 Dennis Costello Central Iowa (191 posts) Registered: 12/29/2007 02:53PM Main British Car: '73 TR 6 '97 Explorer 5.0 |
Re: e10
I used e10 after my engine swap and neglected to consider the cleaning of the fuel tank.
I soon clogged the 10 micron filter to my fuel injectors. I replaced all the fuel hoses with teflon lined and gates barricade. I have one piece of “all fuel” braided covering hose in the engine bay, and can smell fuel if I get close to it. All gasoline has changed since the 70’s and earlier. I’m currently visiting in Michigan, and non-ethanol gas is hard to find. Dennis |
MGBV8 Carl Floyd Kingsport, TN (4366 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB Buick 215 |
Re: e10
Re: e10
Thanks Carl! It turns out there was a Murphy station near our hotel.
In Detroit for the Woodward Dream Cruise. I’m kinda out of my comfort zone among All the muscle cars-and new Mustangs and a Hellcat or two. Why they never get a ticket For noise is a mystery. Plus, everyone on the freeway drives like they are escaping Armageddon! Dennis |
