(2631 posts)
Definitive article on crank driven oil pump swap
Date: August 23, 2021 03:45PM
Rover V8 can use the interim timing cover, this article is for the Buick motors:
[www.turbomalibu.com]
Edited 4 time(s). Last edit at 09/11/2023 04:15PM by mgb260.
(6569 posts)
Re: Definitive article on crank driven oil pump swap
Date: August 23, 2021 09:59PM
He didn't tell how he machined the inside of that gear though did he?
(2631 posts)
Date: August 24, 2021 11:57AM
Jim , no. Mill?
Jim Stabe
Jim Stabe
San Diego, Ca
(830 posts)
02/28/2009 10:01AM
Posted by: Jim Stabe
Date: August 24, 2021 05:24PM
I would imagine that the gear is hardened and would have to be ground.
(6569 posts)
Date: August 24, 2021 05:53PM
That inside corner makes it tough. I'd guess either laser or EDM.
IaTR6
Dennis Costello
Central Iowa
(192 posts)
12/29/2007 02:53PM
'73 TR 6 '97 Explorer 5.0
Posted by: IaTR6
Date: August 24, 2021 08:11PM
I'd just whip out my bespoke broach, and voile', done!
I would like to hear how it was done just because I'm curious.
Dennis
Jim Stabe
Jim Stabe
San Diego, Ca
(830 posts)
02/28/2009 10:01AM
Date: August 24, 2021 08:41PM
Expensive way to make one hole.
(1389 posts)
Date: August 24, 2021 09:20PM
To me it looks ground. I blew up the picture and the edges are rougher than you would expect with a precision cut.
I see that he has two different gears as well. The one in the housing is different than the one used in the description.
The grinding is more evident in the housing picture as well.
No matter how he did it, its a fantastic job well done.
If it where me though, I would have machined the snout of the balancer down to match the 3800 gear while it was in the lathe. Mill the same reliefs on it to engage the gear and avoid all the misery of machining the gear in the first place.
(6569 posts)
Date: August 24, 2021 10:01PM
I'm with you Fred. Makes more sense.
Date: August 25, 2021 07:57PM
All this for a gerotor pump ? Maybe just replace with small block mopar? Little heavier as all iron/steel. Art.
