Goto Page: Previous12
Current Page: 2 of 2
(2633 posts)
Re: Buick 300 V8 build recipe
Date: February 02, 2022 03:48PM
That pin is typical Ford size. Look at 3.78 Ford Turbo 2.3. pistons. You need 1.52 pin height for zero deck. Those are 1.578 but have an extra thick crown and would be no problem to mill .060 off. With a true flat top I would grind off the lug in the chamber and figure 58cc for chamber in the calculator. I get .005 down from zero deck and 10.3 compression. You would have to measure to be sure. You forgot big end size, 7/16" bolts?
Edited 3 time(s). Last edit at 02/02/2022 03:56PM by mgb260.
(2633 posts)
Date: February 02, 2022 04:10PM
Two sets of these would be a good deal. You could use the 305 Chevy ones if you mill .025 off, but you would have to bore the pin end to .924 for the Chevy .927 pin.
[www.ebay.com]
Edited 1 time(s). Last edit at 02/02/2022 04:11PM by mgb260.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Posted by: Airwreckc
Date: February 02, 2022 04:15PM
Thanks again, Jim. Great information. Yes, they are Ford sized, apparently--this is the description from the bay: "SBF SBC 2.00 X 6.320 Carrillo Rods. Nice used set of Carrillo rods from roush racing. Big end is 2.000 with bearning. Takes a .912 pin 6.320 center to center. .902 big end width . Magged good. They have the 7/16 carr bolts." I will definitely check out the 2.3 Turbo pistons. Thanks.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: February 02, 2022 04:35PM
Jim, yes 7/16" bolts. I guess I'll have to compare them to the Buick rods, as you suggest, to make sure there are no clearance issues. I'm only $100 into them, but they look like great rods (if I can make them work).
(2633 posts)
Date: February 02, 2022 04:57PM
Clearance I'm talking about is rotating inside the block. Stock rods have very little room by cam and inside of block. Some have ground the rods to clear the cam and the block for clearance. The thickness of the big end has to be the same or less for side clearance rod to rod. Those rods should take stock SBC small journal bearings. On Chris's build the front two rods hit the shallow part of the pan and the last two hit the windage tray. Ball peen hammer on the pan and washers to space the windage tray down.
Edited 1 time(s). Last edit at 02/02/2022 05:01PM by mgb260.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: February 02, 2022 05:11PM
All good advice--it'll be interesting to see how things work out. Great insight from all of you, as I thought. The 2.3 Turbo pistons look very promising (and super cheap at $14 each).
Edited 1 time(s). Last edit at 02/02/2022 05:14PM by Airwreckc.
(6588 posts)
Date: February 03, 2022 11:56AM
Check the front rod bolt heads against the suction galley casting and the shoulders against the rear cam lobes. .050" clearance is good if you can get it. May have to shave one or two shoulders and recess one or two capscrews.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: February 03, 2022 01:51PM
Thanks Jim, good advice.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: February 05, 2022 08:44AM
I'm getting to tear down my 300. Can anyone suggest a good book (or perhaps Youtube) that will guide this--and also a good manual on rebuilding it. I've rebuild engines before, just not this particular engine. Thanks.
(2633 posts)
Date: February 05, 2022 11:11AM
It isn't much different except the oiling mods and tighter clearances .Do a search here and on V8Buick for more information.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: February 05, 2022 02:02PM
Jim, thanks for the direction.
minorv8
Jukka Harkola
(271 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Posted by: minorv8
Date: February 07, 2022 01:34AM
I have a crank with 91,.5 mm stroke and have later 5.95" SBC rods (for 2,100" journal). I am using special inserts to suit that rod bore and 2,000" journal. That combination clears the cam but did not rotate inside the block. I think I had to grind clearance at 2 locations. The issue was with the cap head bolts and I think I also machined a small chamfer at the head of the rod bolts. I did not like grinding the block at oil gallery that much.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: February 07, 2022 07:58AM
Thanks Jukka, I assume I will also have to chamfer a few of the bolts, as well.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: February 07, 2022 08:04AM
Can someone look at the UEM piston link tthat was previously posted? I checked yesterday and, unless I'm mistaken, they have eliminated the option of searching by bore size and other criteria--making it mush less useful than a few days ago :(
(4628 posts)
Date: February 07, 2022 09:14AM
They have definitely been working on the website. Webmasters seem to think they have to update & modify site just to make them fresh. Doesn't always make them better.
Select a piston brand from Product Lines. Scroll down & use the Filters column on the left to select Bore Diameter. Not quite as handy or useful as it was, though.
Glad they kept the calculators.
Edited 1 time(s). Last edit at 02/07/2022 02:11PM by MGBV8.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: February 07, 2022 09:45AM
Thanks Carl, wanted to be sure I wasn't missing something. What was a five minute search will now take a lot longer. Oh well.
(2633 posts)
Date: February 07, 2022 10:53AM
Jukka, Did your rods have 7/16" bolts? That will add to the width over the 3/8".
minorv8
Jukka Harkola
(271 posts)
04/08/2009 06:50AM
Posted by: minorv8
Date: February 07, 2022 11:10AM
Yes, 7/16" bolts. But since my rod bid end width had to be a touch over 0.76" it did not matter whether they are 3/8" or 7/16".
The crank is a weird stroker item for TVR500 i.e. 5.0 litre version.
(2633 posts)
Date: November 24, 2023 02:31AM
New forged pistons available for the Buick 300 V8:
[dssracing.com]
