donfaber Don Faber Terra Alta WV (120 posts) Registered: 10/31/2007 10:53PM Main British Car: 1979 MGB 3.9L Rover V8 |
timing tape or timing tag - 3.9L rover V8
Just had my distributor rebuilt - I've been advised to set timing at 18 deg before tdc. My flywheel has no marking - has anyone used timing tape or timing tab on these engines? Source? Thanks
Re: timing tape or timing tag - 3.9L rover V8
You should be able to use a dial-back timing light.
