turbodave
dave cox
(181 posts)
04/30/2018 03:00PM
SD1
Run crower 50232 with solid lifters?
Posted by: turbodave
Date: November 12, 2022 09:23PM
Thoughts on running solid vs hydraulic on a cam like this?
I already have adjustable forged rockers; just wondering if there is any significant gains to be had going solid?
(2463 posts)
Re: Run crower 50232 with solid lifters?
Date: November 12, 2022 09:38PM
You need an adjustable rocker setup or adjustable pushrods. You will gain a little top end. Acts like a smaller cam. Recommend the lifters with the small oil hole on the face. Will have to experiment with closer valve lash.
[www.motortrend.com]
Edited 1 time(s). Last edit at 11/12/2022 09:40PM by mgb260.
(4512 posts)
Date: November 13, 2022 09:28AM
Was not aware you could do that. I have the same cam still in the box patiently waiting.
I have a solid lift cam in my ol' Camaro because adjusting hydraulic lifters was so messy.
minorv8
Jukka Harkola
(269 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Posted by: minorv8
Date: November 14, 2022 01:06AM
That is a pretty mild cam. The only real reason for solid lifters is that hydraulic lifters would not allow high revs. I doubt very much that this cam requires solid lifters.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: November 14, 2022 01:13PM
The Crower 50232 with hydraulic lifter combination is fine - ran that combo in my Olds 215...largely due to the recommendation of Dan Lagrou at D&D. who promoted that cam profile for the BOPR engine.
Date: November 15, 2022 11:14AM
Using solids should result in a little more lift and duration. Not much, but the ramp used to engage the hydraulics becomes part of the cam profile instead.
