Goto Page: 1234567891011...LastNext
Current Page: 1 of 12
(6590 posts)
Max valve size for 4.0/4.6 heads?
Date: December 08, 2022 11:26AM
Anyone know how large you can go on the valves for these heads without changing the seats?
I've seen valves about .050" larger for both ex and intake. That hardly seems worth the trouble and expense unless the old ones have to be replaced.
(2633 posts)
Re: Max valve size for 4.0/4.6 heads?
Date: December 08, 2022 11:32AM
Rimmer bros and the Wedge Shop sell larger valve for the Rover heads. Pretty close to the Buick 300 sizes. Years ago I changed the seats and used Ford 2.3 SOHC 1.74 IN and 1.5 EX valves in a 300 head. Probably could in the Rover also.
(6590 posts)
Date: December 08, 2022 11:47AM
That'd be a substantial increase. The intake is about 1.570 and the exhaust is about 1.350. The alloy 300 heads have a little larger intakes and smaller exhausts, around .040 difference in each case I think. There is slightly over 3/16 between the valves so I expect that'd be about the limit.
Just for reference the TA heads have the valves repositioned and can go bigger, up to 1.6 and 2.0 in although we decided a 1.9 made more sense.
(2633 posts)
Date: December 08, 2022 02:38PM
Larger Rover valve sizes in this link:
[thewedgeshopstore.com]
Date: December 08, 2022 02:57PM
Ok TWS. lets see the flow $'s for $2,100 ?
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Posted by: Airwreckc
Date: December 08, 2022 03:08PM
In case anyone is interested, here's a slightly less expensive alternative. Price is 1550 GBF plus 200 GBF (core). They are CNC ported and the size of the valves is 1.63" intake and 1.4" exhaust. I've asked for flow numbers.
[johnealesroverv8.co.uk]
(2633 posts)
Date: December 08, 2022 03:19PM
Eric, Plus shipping back and forth. Wedge Shop (TWS) might be more like their Stage 3 too.
Edited 1 time(s). Last edit at 12/08/2022 03:20PM by mgb260.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: December 08, 2022 03:39PM
Jim, agreed.
(6590 posts)
Date: December 08, 2022 04:46PM
Saw those, not real impressed with the valve sizes. I mean if I'm spending $18 each for valves I'd want to get a little more than that I think. Probably just stick with the originals, they seem to be in good shape.
minorv8
Jukka Harkola
(271 posts)
04/08/2009 06:50AM
Morris Minor Rover V8
Posted by: minorv8
Date: December 09, 2022 02:21AM
Hi,
1,63" intake and 1,40" exhaust valves are typically available and fit factory seats. Thatīs what I have fitted in my Rover heads.
One thing to consider: I have not had much luck finding uprated springs (read inexpensive) for Rover heads. Sure there are double springs available but all the additional parts + possible machining start adding up costs. Also quality of rockers and rocker shafts is pretty poor. I have a pair of new rockers shafts that have smaller OD than worn factory shafts. These came from a reputable source in UK.
Jukka
minorv8
Jukka Harkola
(271 posts)
04/08/2009 06:50AM
Posted by: minorv8
Date: December 09, 2022 02:30AM
Here is a link to a UK magazine article from mid 90īs when P38 type 4,0 / 4,6 litre engines arrived. It has some useful info about component dimensions
[drive.google.com]
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: December 09, 2022 09:33AM
Jukka,
That's a very useful article. I'm curious about one thing. The article says the 4.6 heads have a combustion chamber of 28 to 31 cc, while I think I've read somewhere else that they are 22 cc. Am I missing something? That would make a big difference in my calculations.
(4629 posts)
Date: December 09, 2022 10:02AM
Never, ever heard 22cc, Eric. More like 28 to 29cc.
There are few odd remarks in that article.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: December 09, 2022 10:43AM
Carl,
Probably need to get my eyes checked. Thanks for the confirmation--now have to redo my calculations.
(4629 posts)
Date: December 09, 2022 01:32PM
"So, in addition to deleting these bolts a new thicker composite head gasket has been introduced, and the deck height has been reduced by a corresponding amount."
Say what?! In all these years, I have never heard that the deck height was changed.
"...and the production conrods and pistons remained weak."
Do the Rover V8 engines not use a forged connecting rod? I know that the Buick/Olds 215 does.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: December 09, 2022 01:52PM
Carl,
I did read somewhere else that the later Rover heads used a thicker gasket and that the combustion chamber was accordingly reduced by shaving the head--I *think* that's what the article was trying to say, but it made it sound like it was the block that was reduced, which I don't think was the case. Still wondering where I saw that 22 cc reference...
Not sure about the Rover rods, though.
(4629 posts)
Date: December 09, 2022 02:29PM
Yes, Rover shaved the heads to compensate for the thicker composite head gasket. I think they are wrong about the deck height.
(6590 posts)
Date: December 09, 2022 04:49PM
That would explain the change in chamber volume.
The 340 used cast rods, pretty sure the 300 did too. One of the early mods to the 215 was to use small journal SBC rods which were forged. How certain are you that the 215 rods were forged?
That 22cc number may have been my fault, I had mentioned that as a piston dish volume because I had some notes from an old engine build that contained that figure. But apparently I never actually used it so as far as I know it doesn't apply to any build.
22cc would be a VERY small chamber volume.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: December 09, 2022 04:55PM
Ha, no worries on the chamber volume--my numbers do work a bit better now, though :)
I have also read that the 215s had forged rods--I think that was from a spec sheet posted on the V8 Buick site.
(4629 posts)
Date: December 09, 2022 07:24PM
I'd bet on it, Jim. ;)
