Re: Max valve size for 4.0/4.6 heads?
Yeah, it was always going to, as the original dia at the bottom was fixed, and larger than the dia of the Rover version. Top of the spring is approx .17” below the top of the valve (need to confirm) and was machined reference to this face - they certainly appeared to be very consistent; I checked each one against a valve and retainers as they came off the lathe.
So we will still need to dig-out the spring pockets a little, but less than using any other retainers… Edited 1 time(s). Last edit at 03/23/2023 11:10AM by turbodave. |
BlownMGB-V8 Jim Blackwood 9406 Gunpowder Rd., Florence, KY 41042 (6578 posts) Registered: 10/23/2007 12:59PM Main British Car: 1971 MGB Blown,Injected,Intercooled Buick 340/AA80E/JagIRS |
Can't wait to get those, and just in time too. I have an appointment in WV on Monday so a trip to drop those off with Dustin will be in order and I may even be able to put the 340 back together by summertime. Haven't given a lot of thought to how I might rework that engine's blower mount to be a lower height but it raises possibilities.
Might be. My heads are at the shop to be machined for final assembly using the PAC springs. Might be done in a couple weeks.
One of the advantages of staying close to stock height is not having to shim the rocker pedestals to maintain geometry but the longer stems on the valves in my TA heads did not cause much of an issue fitting under the MGB repop valve covers so clearance doesn't seem to be much of a problem. Just had to trim a small notch in the boss for the oil filler plug to clear the chevy stud type adjusters. To go over .550" lift I'm sure a longer valve is needed though. I agree it took a lot of effort to get here but I sure do appreciate your help. I have that bottle sitting on the shelf, the car's back together and all we have to do is figure out the schedule to make that visit happen. Jim |
Still need to do the rocker shafts. These will go on the 340. I still need to order the cam and main bearings but it will go back together this summer. I have the options of using the old intercooled blower intake, (too tall) an iron 4bbl intake, making a new blower intake, or using spacers with a 300 intake. I'm leaning towards making another blower intake. Maybe I'll post the old one in the classifieds or something. Jim |
Dustin did the final assembly so I really don't know. He told me he had to cut the pockets .050" deeper and used a .015" steel shim for a seat. Had .600" range of motion so my .550" lift is OK. Had to cut the guides .150". Installed height should be around 1.7" but I'm not taking it back apart to check. He felt the open and closed pressures were appropriate for a solid lifter cam, and from earlier calculations I think probably around 350 open and 150 seated. I think those were about the numbers he was throwing around. Really my only complaint is that instead of ordering the pocket cutter for the LS springs he used one he had and it cut the pockets bigger than they needed to be but they won't dance around enough to contact the seals so I think it'll be fine.
