hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Crankshaft surface hardening???
Posted by: hoffbug
Date: February 02, 2009 10:22AM
I have aROver 4.6 crank that I am going to have the rod journals offset ground to give a 3.4" stroke.
I was wondering if the factory did any nitriding, tuftriding, other other surface hardening on these cranks?
Im guessing that any offset grinding would cut through what little penetration there is .. requiring another round of treatment.
V8Tech
Shaun O'Donnell
(19 posts)
01/12/2009 11:37AM
Re: Crankshaft surface hardening???
Posted by: V8Tech
Date: February 09, 2009 09:18AM
Hi Tony,
Although some later cranks were treated at the factory most were not. I would always recommend Tuftride if budget allows, especially on an 86.36 offset ground crank.
Are you building yourself a 4.8? or are you going for 5.0 with bigger bores?
Shaun
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: February 09, 2009 01:37PM
Initial plans are for a 4.8.. 294 CI..
.I have the T-top liners from westwood for a 4.6...
3.9 / 4.0 / 4.2 / 4.6 Litre Engines, Part Number WCL 36GFL
ID : 94.00mm (with allowance for finishing)
OD : 99.06mm
Flange OD : 105.23mm
Flange Depth : 5.33mm
Length : 135.64mm
Any idea what the safe overbore is for those?
