Tremec 5 spd looks like a T5 ?
Date: December 19, 2022 02:21PM
Perhaps I missed something ? A JH for sale list this trans. Is it better somehow ?
Thanks, Art.
mstemp
Mike Stemp
Calgary, Canada
(223 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Re: Tremec 5 spd looks like a T5 ?
Posted by: mstemp
Date: December 19, 2022 03:23PM
Tremec have the later upgraded spec than the usual T5 is my understanding. I recall the Tremec versions have 330 lb ft rating, like the Ford M-7003-Z. Better brg and synchro rings etc. But look the same as most T5.
Date: December 19, 2022 03:58PM
Could be a difference in the input and output shaft sizes. I have a Tremec and the shafts were larger. Had to get a different clutch disc and driveshaft yoke.
Roverbeam
Chad McNeely
N.E. MO
(76 posts)
06/09/2021 06:03PM
Alpine S4 Rover 4.0
Posted by: Roverbeam
Date: December 19, 2022 04:26PM
Tremec bought the design from Borg Warner. Those built after the company change are called by the new name. Same transmission though. And just like under BW, the models continued to vary by their application with a range of shaft sizes, spline counts, tail shaft shapes, bell housing patterns, and gear ratios. It's sort of the ultimate chameleon product - one name, many many flavors, and much of them interchangeable. I have an S10 pickup version modded to all WC mustang internals, going from a GM input shaft to Ford, and from 3.76 first gear to 2.95, but with the forward-shifter S10 shape.
MG four six eight
Bill Jacobson
Wa state
(325 posts)
10/23/2007 02:15AM
Posted by: MG four six eight
Date: December 25, 2022 12:59AM
Back in 2000, I bought a new V8 Camaro T-5 from work (GM dealership). On the way home from the British V8 meet in Ohio that year, it developed a bearing noise and had a bunch of metal in the fluid. It was covered under the parts warranty and the replacement was a Tremec version. If I remember correctly, I think that it had the same part number and it was identical to the Borg Warner version.
Edited 2 time(s). Last edit at 12/25/2022 01:04AM by MG four six eight.
