62Healeyhacker
Jerry Jackman
(19 posts)
04/11/2009 10:58PM
I want to use a crossbolted 4.0 block but only have small journal crankshaft.
Posted by: 62Healeyhacker
Date: March 22, 2023 08:28PM
Is there a way to adapt the larger, 2.5 inch, mains in the block to the crankshaft with the Buick 215" 2.3 inch journals?
(4627 posts)
Re: I want to use a crossbolted 4.0 block but only have small journal crankshaft.
Date: March 23, 2023 09:53AM
Over the years, that is one trick that I have never come across. It will be faster & cheaper to find a 4.0 crank or a 3.9 block.
turbodave
dave cox
(196 posts)
04/30/2018 03:00PM
SD1
Posted by: turbodave
Date: March 23, 2023 10:31AM
Find a block from a 1995 discovery - even better if you can find one with a build date in the second half of 1995, and it'll have the tall caps in the block. It won't be cross-bolted, but thats an easy machining operation for an experienced shop. You WILL need to line-bore afterwards, but again, no real difficulty for the right shop.
ag1234
Arthur Gertz
(158 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: March 30, 2023 01:45PM
More direct is better. Use 4L. crank=simpler,stronger and easier to balance. Good Luck, Art.
