phongshader
Justin Brown
Ca
(63 posts)
02/19/2010 04:03PM
Locost Lotus 7 2.3 Duratec
215 crank with 1.850" rod journals?
Posted by: phongshader
Date: March 28, 2023 01:36AM
Would grinding down the rod journals to 1.850" significantly weaken the 215 crank? It's not like it's going to be making 600hp...maybe 200hp at best. Anyhow do you all think it would present any longevity problems/bad idea?
phongshader
Justin Brown
Ca
(63 posts)
02/19/2010 04:03PM
Re: 215 crank with 1.850" rod journals?
Date: March 30, 2023 11:22AM
Wow, no opinions...So I bought some 6.2" Nascar rods that need 1.850" rod journals and want to install them into a Olds 215 block with Nissan KA24 Silv-O-LitePistons 9115.5MM. Is this a bad idea? I know the gains will probably not justify the cost but...will the smaller journals compromise the engine in a significant way?
Roverbeam
Chad McNeely
N.E. MO
(81 posts)
06/09/2021 06:03PM
Alpine S4 Rover 4.0
Posted by: Roverbeam
Date: March 30, 2023 12:11PM
Just based on simple section modulus formulas, a round "beam" has strength related to the cube of its diameter. Going from D=2" (d^3=8) to D=1.85" (D^3=6.3), you'll have about 80% (6.3 ÷ 8) of the crank's strength remaining. Up to you if that's "strong enough"!
Can't comment on the rest of the combination without more specifics - piston height and dish volume, block decking, gasket thickness, head volume, and whether you're offset grinding the crank to add stroke...
ag1234
Arthur Gertz
(158 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: March 30, 2023 01:30PM
Hi Justin, many changes for little reward This weakens a cast crank, needlessly. 6.2" rod and 2.8" stroke = reduced rod angle.This is not good for your application. Better rod ratio is 1.7/1.8/1. Good Luck, Art.
7sand8s
Dennis Miller
(36 posts)
09/21/2008 10:47PM
Posted by: 7sand8s
Date: March 31, 2023 06:59AM
That should be ok.
It would reduce the journal overlap only 0.15.
Rod/stroke from 2.02 to 2.21.
Less wear on the thust side of the block.
phongshader
Justin Brown
Ca
(63 posts)
02/19/2010 04:03PM
Date: March 31, 2023 10:20PM
I always thought there was more to be gained from by a bigger rod/stroke ratio than just less wear on the thrust side of the block particularly with heads with small ports...like the Olds heads ¯\_(ツ)_/¯
