Goto Page: Previous12
Current Page: 2 of 2
(4615 posts)
Re: TA Heads for 300, 350 question
Date: February 18, 2024 10:05AM
The timing cover should not get any hotter than the engine oil or water temp. Likely cooler when the car is moving.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Posted by: Airwreckc
Date: February 18, 2024 10:25AM
Carl, that's what I was thinking, as well. Thanks for the input.
(2631 posts)
Date: February 18, 2024 11:34AM
I like J-B weld.
[www.jbweld.com]
Spitfire 350
Phil McConnell
Perrysburg, OH (Toledo area)
(259 posts)
01/11/2010 09:19PM
74 Spitfire 350Chevy
Posted by: Spitfire 350
Date: February 18, 2024 05:22PM
I used to use JBWeld to block off water jackets in rotary engines, never had a leak. I was turning side port engines into internal peripheral port engines. That is until the SCCA outlawed the blocking off of water jackets in rotary engines.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: February 18, 2024 06:25PM
Good to know. I think there's an aluminum filled JB Weld that's high temperature, too.
(6569 posts)
Date: February 19, 2024 08:28AM
I may decide to use the JB weld on my TA heads when I get to it. Be a good idea to drill a shallow hole to act as a locator for the plug if you do, so if it should get loose it can't move. Something to act as a mechanical lock. After all, aluminum does have that oxide layer.
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Date: February 19, 2024 08:47AM
Jim,
I'm also looking at this stuff. Supposed to be even stronger and more tenacious JB Weld and rated to 150C. I believe it is a Epoxy Cyanoacrylate hybrid. Might be interesting to try a little test to compare to JB.
[a.co]
(6569 posts)
Date: February 19, 2024 09:08AM
Chinese version of JB Weld? I'd stick to proven products for this. Devcon or JB weld. Or have it heliarced then you never have to wonder about it.
(4615 posts)
Date: February 19, 2024 12:47PM
Teenanseen - As seen on TV? :D
