MGBV8 Carl Floyd Kingsport, TN (4627 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB Buick 215 |
Re: TA Heads for 300, 350 question
The timing cover should not get any hotter than the engine oil or water temp. Likely cooler when the car is moving.
Airwreckc Eric Cumming RTP, North Carolina (253 posts) Registered: 05/28/2020 10:10AM Main British Car: 1972 MGB-GT (working on a Sebring project) Buick 300-4 V8 |
Carl, that's what I was thinking, as well. Thanks for the input.
Spitfire 350 Phil McConnell Perrysburg, OH (Toledo area) (259 posts) Registered: 01/11/2010 09:19PM Main British Car: 74 Spitfire 350Chevy |
I used to use JBWeld to block off water jackets in rotary engines, never had a leak. I was turning side port engines into internal peripheral port engines. That is until the SCCA outlawed the blocking off of water jackets in rotary engines.
Good to know. I think there's an aluminum filled JB Weld that's high temperature, too.
BlownMGB-V8 Jim Blackwood 9406 Gunpowder Rd., Florence, KY 41042 (6586 posts) Registered: 10/23/2007 12:59PM Main British Car: 1971 MGB Blown,Injected,Intercooled Buick 340/AA80E/JagIRS |
I may decide to use the JB weld on my TA heads when I get to it. Be a good idea to drill a shallow hole to act as a locator for the plug if you do, so if it should get loose it can't move. Something to act as a mechanical lock. After all, aluminum does have that oxide layer.
Jim,
I'm also looking at this stuff. Supposed to be even stronger and more tenacious JB Weld and rated to 150C. I believe it is a Epoxy Cyanoacrylate hybrid. Might be interesting to try a little test to compare to JB. [a.co] |
Chinese version of JB Weld? I'd stick to proven products for this. Devcon or JB weld. Or have it heliarced then you never have to wonder about it.
