cjm76
Chris Mcnic
(2 posts)
03/30/2024 03:57AM
Carb size blower motor
Posted by: cjm76
Date: March 30, 2024 04:02AM
Hi there has anyone fit a 4-71 to rover 3.5?
I’m looking for info on carb size choice please
(6586 posts)
Re: Carb size blower motor
Date: March 30, 2024 11:25AM
I used an Eaton M-90. Also a turbo, and M120/340cid. I used EFI except for the turbo.
For draw through applications the blower will boost the draw through the carb well beyond the 1.2 inches a modern 4bbl carb is rated at, so that in practical terms a blower engine will not be carb limited. If you want to get way down in the weeds about it there are efficiency curves that you can use to determine optimal carb size and inlet vacuum under full boost but bear in mind that idle, off idle and midrange performance are frequently even more important.
I tend to calculate the effective displacement using the expected boost as a multiplier and use that as an upper limit, based on the specs of the engine itself. A race engine and a street engine will have very different needs of course.
(4637 posts)
Date: March 31, 2024 05:45PM
Welcome to BritishV8, Chris.
This article doesn't begin to answer your question, but I'd bet it will interest and inspire you nonetheless:
Under-Hood Eaton M90 Supercharger (on an MGB w/ Buick 215 V8)
cjm76
Chris Mcnic
(2 posts)
03/30/2024 03:57AM
Posted by: cjm76
Date: April 01, 2024 02:05AM
Thank you for the replies
Blown v8
Bryan Phipps
(72 posts)
03/10/2013 04:52PM
Posted by: Blown v8
Date: April 01, 2024 01:13PM
When I had the wade Ro34 on a 3:5 I used a jetted 390cfm
When I went to the 4:71 I used a 600 cfm, I had it set up on a rolling road, Worked really well,
I never used the choke, on either
ag1234
Arthur Gertz
(158 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: April 09, 2024 12:14PM
Using 4-71 for looks, not efficiency ? Boost target ? I selected a 6V-71. Perfect length and size. Weld adapted an Offy single plane intake. This makes for a clean package and will make adequate boost.
Onward, Art.
ag1234
Arthur Gertz
(158 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: April 25, 2024 01:06AM
Beautiful build, Bill ! How much boost ? How doest it scoot ?
Onward, Art.
MG four six eight
Bill Jacobson
Wa state
(326 posts)
10/23/2007 02:15AM
Posted by: MG four six eight
Date: April 28, 2024 01:15PM
Thanks Art,
I run 11 psi of boost and she goes pretty good. I beefed up the bottom end with forged pistons, ARP studs, line bored the block, balanced, etc, so I'm sure that the motor could take a little more boost. However the car can struggle for traction at times as is, so additional boost would probably mean just more "smoke and noise" ;-)
Bill
(1389 posts)
Date: April 30, 2024 11:50PM
Turning gasoline into smoke and noise,
I love it!
Live like you mean it
Go Canucks Go!
