Re: Rover 3500 front cover??? harmonic balancer???
That looks like the "300" cover to me. With a high volume pump mod.
Could be wrong, Jim B would know for sure. |
Good call on the Buick 300. I took the harmonic balancer off and decoded the timing cover part number. It did turn out to be a Buick 300 cover. The harmonic balancer is also Buick 300.
Since this has a Buick 300 harmonic balancer - I am speculating that the crank is also Buick 300. Is this a common modification for the Buick 215? |
MGBV8 Carl Floyd Kingsport, TN (4630 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB Buick 215 |
Yes, 215 stroker engine using a Buick 300 crank, along with the harmonic balancer & flywheel since it is externally balanced.
