buickv8s
Steve W
(11 posts)
05/14/2024 11:29AM
Block Identification - Rover 3500 / 3.5 liter? shim plate?
Posted by: buickv8s
Date: May 15, 2024 07:53AM
I am having trouble identifying this block after searching on the internet for block casting / stamping numbers. The intake, timing cover, water pump, and harmonic balancer on this engine are all Buick 215 parts verified by their casting numbers. But this block is definitely not a Buick 215 block. There is no pad / ledge at the front where the Buick 215 numbers are stamped. This block has some numbers stamped at the back on the bell housing "ear."
Is this a Rover 3500 engine? Can anyone tell what year or era or size it is by these numbers?
What is the deal with the shim plate behind the flex plate - is this typical for Rover to get the correct torque converter clearance? Or is this typical for the Buick 215?
Thanks for the help!
(4629 posts)
Re: Block Identification - Rover 3500 / 3.5 liter? shim plate?
Date: May 15, 2024 09:47AM
Early Rover P6.
[rimmerbros.com]
ag1234
Arthur Gertz
(159 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: May 19, 2024 03:01PM
About that shim, likely used on the Buick 2 speed auto, (air cooled). Cooling air is drawn, centrifugal over aluminum cooling fins of bolt-together, 5 element/ Dual-path, torque convertor. Air exhaust through elephant ears, on back of block. Otherwise known a baby Dynaflow. TMI, Art.
buickv8s
Steve W
(11 posts)
05/14/2024 11:29AM
Posted by: buickv8s
Date: May 20, 2024 08:57AM
Now it makes sense why the shim is cut back at the two ears - to let more air flow through. The transmission case matches this shape.
