VR1 - the best RV8 oil?
Lake Speed jr certainly thinks so, and my budget endurance race engine seems to be lasting well
Anyways, it’s $27 for 5 quarts on Amazon, Walmart.com and also in Walmart stores. I’ve not seen it this cheap for at least 4 or 5 years. I don’t recall them stocking it before to be honest, but every store near me shows in stock on the shelf, so that’s how it is now at least… just got three jugs while picking up a few other items. Edited 1 time(s). Last edit at 05/30/2024 07:12PM by turbodave. |
MGBV8 Carl Floyd Kingsport, TN (4559 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB Buick 215 |
Re: VR1 - the best RV8 oil?
Or Castrol Classic 20W50.
If wanting synthetic, Mobil 1 15W50 looked good as of 2021. [bobistheoilguy.com] |
joe_padavano Joseph Padavano Northern Virginia (160 posts) Registered: 02/15/2010 03:49PM Main British Car: 1962 F-85 Deluxe wagon 215 Olds |
Pretty much any one of the high zinc oils will be equivalent. There is probably more time wasted discussing this topic on the interwebs than almost any other. Pick one, put it in the engine, and drive. As for 20W-50, why? For a stock or near-stock engine, the extra viscosity just means lost HP and more strain on the oil pump.
My factory chassis service manual says 10W-30 or 10W-40 for an Olds 215. No GM gas engine was ever spec'd for 20W-50 oil unless you were using it in the Sahara.
Hmm. I was told 20W50 & have been using it for 23 years. Some of that quite abusive. ;) I tried 10W40 once. The oil pressure dropped.
Seems Rimmer Bros says 10W40 for the Rover V8s. [rimmerbros.com] Over at RPI Engineering, they say "Valvoline VR1 20w/50 is the only oil we use and recommend for the Rover V8". |
