ag1234
Arthur Gertz
(159 posts)
03/29/2023 08:26PM
Two, two barrels, really ?
Posted by: ag1234
Date: August 09, 2024 05:54PM
Dare to be different, your results may vary. RV8 with Offy SP. manifold. New Carter BBD;s are about $60.ea., now. Adequate flow.
Mash good, Art.
Dan Jones
Dan Jones
St. Louis, Missouri
(311 posts)
07/21/2008 03:32PM
Re: Two, two barrels, really ?
Posted by: Dan Jones
Date: August 11, 2024 09:46PM
Offenhauser made two different 2 x 2 barrel intake manifolds for the Buick/Olds/Rover aluminum V8. The basic one was part number 5164 and was an Equa-Flow design, sort of a single plane but split plenum and very short runners (mostly plenum) and was drilled for 3 bolt Stromberg or small pattern 4 bolt Rochester 2GC carbs. Part number 5262 was the same intake but drilled and bored for the large pattern Rochester 2G carbs. Edelbrock also made a 2 x 2 barrel intake manifold but it was a dual plane. I had one and, compared to the later Edelbrock Performer Rover, it has longer inner runners and shorter outer runners and is symmetric front to rear. The Edelbrock intake was dyno tested in "Modifying GM's Aluminum V8s" Hot Rod Magazine June 1961. In the "Souping the Special" chapter of the 1963 "Hot Rodding the Buick" book (by Bob Russo, Spotlite Books #537 from Hot Rod Magazine) there are pictures of both the Edelbrock and Offenhauser 2 x 2 barrel intake manifolds.
I assume those are Chinese copies. Are tuning parts available? The Rochester 2GC carbs were used in circle track applications and you can get tuning parts like jets.
ag1234
Arthur Gertz
(159 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: August 16, 2024 08:47AM
Dan,
Remains to be seen on BBD tuning parts,( Carter) ? I see flow enhancement potential with all these manifolds. Underside of all throttle bores are sharp ! I will start with a large diameter dovetail cutter and finish with suitable porting burr. I suspect carb spacers, with anti-reversion, should help. Cheers, Art.
Dan Jones
Dan Jones
St. Louis, Missouri
(311 posts)
07/21/2008 03:32PM
Date: August 17, 2024 10:34PM
Art, this one is for sale on Facebook (Cookeville, TN) and has the Offenhauser 2x2 barrel intake and Offenhauser valve covers with matching finned air cleaner and some sort of custom oil pan. It's an Oldsmobile 215 stroked with a Buick 300 crankshaft Silvolite Ford/Mazda 3.0L V6 pistons (hypereutectic with coated skirts, 1.5/1.5/4.0 mm rings). That combo can be built with either 5.7" SBC or 5.66" 215 rods.
ag1234
Arthur Gertz
(159 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: August 30, 2024 12:40PM
I would be concerned about durability of 215 rods in a stroker, I hope build, in picture has good baffling of flat-bottom pan. Needs 300 Buick exhaust manifolds. Onward, Art.
(4628 posts)
Date: August 30, 2024 03:48PM
The Buick/Olds 215 & Rover V8 3.5-4.2 rods are forged, Art.
Dan Jones
Dan Jones
St. Louis, Missouri
(311 posts)
07/21/2008 03:32PM
Date: August 30, 2024 05:02PM
At least the Buick 215 rods are forged unlike the later Buick 300/340/350 rods. Yeah that pan definitely needs trap doors.
ag1234
Arthur Gertz
(159 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: September 03, 2024 01:43PM
IMHO, 215 and 3,5L rods were neve designed for the loads of a .600" stoke increase,
(6587 posts)
Date: September 04, 2024 07:23AM
I like the ex-nascar Pankle and Carillo rods you can buy for a little over a C note on ebay for a full set but IDK if you could find short enough ones for a stroker 215.
