(6585 posts)
Oil filler thread size
Date: September 10, 2024 05:16PM
Anyone know the actual thread size and pitch of the opening in the Rover valve cover for the oil fill plug/flame arrestor/etc? I make it to be about 41.75mm and about a 2.25mm pitch but that is nowhere near a standard size.
(4626 posts)
Re: Oil filler thread size
Date: September 11, 2024 12:28PM
No, but I can bring an oil filler plug to Townsend if it will help.
Roverbeam
Chad McNeely
N.E. MO
(81 posts)
06/09/2021 06:03PM
Alpine S4 Rover 4.0
Posted by: Roverbeam
Date: September 11, 2024 03:24PM
1 1/4" BSPP
I bought a plastic (dummy) one from McMaster to test fit - it worked.
This site gives the thread specs, approximating Jim's metric measurements:
[amesweb.info]
Parameter Value
Pipe Thread Size 1 1/4
Threads per inch 11
Pitch of Thread 2.309mm
Basic Height of Thread 1.479mm
Height of Sharp V Thread 2.218mm
Major Diameter of Thread 41.910mm
Pitch Diameter of Thread 40.431mm
Minor Diameter of Thread 38.952mm
Edited 1 time(s). Last edit at 09/11/2024 03:30PM by Roverbeam.
(4626 posts)
Date: September 11, 2024 05:02PM
This thread gives the same answer as Chad, 1 1/4" x 11 BSP.
[www.pistonheads.com]
(6585 posts)
Date: September 12, 2024 09:14AM
Figured it was something like that. Best price so far on a tap is about $47 which is actually quite fair really but a good bit to pay for a single use tool. Much cheaper and easier than making one though. Thanks all, and I will double check the thread pitch this morning. Should fit the 11 tpi gage perfectly I would expect. It should allow me some lattitude in configuring valve cover vents and such.
