smelfi Steve Melfi Alexandria Ohio (90 posts) Registered: 04/26/2008 07:35AM Main British Car: 1977 MGB 302 |
Canton oil pan part number
I've been lurking on this site for several years and I'm hoping to get going on my 78 B conversion to a 5.0 Ford within the next month or so. I have the engine, a T5, and an 8.8 rear end. I'm making a list of parts I need and am stuck on finding the right Canton oil pan. I've been to the Canton site and can't determine which rear sump to get, there are several small block ford rear sumps listed on the site. I've searched this site and another MGB V8 site for the part number.
Anyone know the part number of the oil pan? Thanks, Steve Melfi |
Re: Canton oil pan part number
I don't know the part number... but I bet Pete Mantell does.
Pete actually showed two different Canton oil pans in these two articles, and both articles include photos: Pete's 2007 tech session Pete's 2006 tech session Pete's contact info is here: [www.britishv8.org] |
kstevusa kelly stevenson Southern Middle Tennessee (986 posts) Registered: 10/25/2007 09:37AM Main British Car: 2003 Jaguar XK8 Coupe 4.2L DOHC/ VVT / 6sp. AT |
Perhaps you would consider a Ford Bronco rear sump pan. they have their own pick up and will fit the application. these come from early 80's and have been used in some conversions. i just took the 5.0 mustang pan and cut the front hump out and replaced with sheet metal and added a reworked pickup from a rear sump 5.0
Just a thought. SAFETY FASTER! |
jbarila John Barilaro Red Sox Nation! (60 posts) Registered: 11/02/2007 08:29AM Main British Car: 1977 MGB Ford 302/5L |
I have a canton pan but went with the Bronco pan instead because I already had the correct pickup. I was given the Canton and plan on selling it. The Bronco pan fit perfectly and was really cheap.
Thanks for the inputs and ideas guys. Since my original post on this I went to the Jegs web site and found about 10 or so small block ford rear sump pans listed. When I get some time I'll go to the manufacturers sites for more in depth descriptions and specs on those pans.
John, I haven't discounted the Bronco pan idea you suggested. Steve |
Not the Canton one, but a ford racing one... [www.amazon.com]
I wasn't even aware there was a rear sump pan/pick-up... how shallow is it? E.g., does it enable doing the Ford 5.0 w/o modifying the cross member? Can't imagine it's that shallow, but figured I'd ask. |
Rob,
When I clicked on the amazon link it went to a ford 429/460 oil pan. In the jegs online catalog I've found around ten 5.0 rear sump pans, most manufactured by Moroso. I'm considering either a Bronco pan or the Moroso part number 20521. I'm pretty sure the cross member still needs modified with both. The rear sump pans sort of have two sumps, a shallow one about 6 1/2 inches deep in the front for oil pump clearance, and the main sump in the rear. By the way, I think I'll finally be welding those engine mounts on that I bought from you quite a while back. Steve Melfi |
Guys, I'm no Ford expert but what's the difference in pans between a 302 and a 351 Windsor? Speedway auto has rear sump "claimer" pans for the 351W with pickups for around $100. [www.speedwaymotors.com]
