Doc Hopalongfoot Marc Weitzman Huntingto Woods, MI (58 posts) Registered: 01/22/2008 11:45PM Main British Car: 1979 MGB roadster ford 302 |
1995 Six speed trans. from V8 Camaro
Just saw some ads for 1995 LT1 Camaros with 6 sp. trans. Will these transmissions fit in a B?
Marc |
Re: 1995 Six speed trans. from V8 Camaro
Doc, I don't think it will fit without a lot of metal work on the tunnel. The T56 is quite a bit larger than the T5. Calvin Grannis is using one in his conversion and there are some photos in his postings on the Triumph section.
Some guys say yes, some say no. A lot depends on how far forward your engine is.
Thanks Bill, I didn't know that there was such a huge difference in size between them.
Marc |
The T56 is a biggun.
For sure. Wide too. Which is more concerning... That said, Calvin has found a place that moves the shifter to the front cover - or forward quite a ways. Check out his build diary in the Rumf forum. |
I would question why someone would want to put that many gears in a light vehicle. For a 2500lb vehicle like an MGB, 5 forward speeds is more than enough.
BMC Brian Mc Cullough Forest Lake, Minnesota, USA (384 posts) Registered: 10/30/2007 02:27AM Main British Car: 1980 MGB '95 3.4L 'L32' SFI V6, GM V6T5 & 3 |
I would love a 6 speed in my car but honestly, it makes no sense. It costs more which is not needed and it is just not needed. It makes far more sense to change your rear axle and suspension. You can accelerate faster and better this way.
-BMC. |
Yeah, that's what they said about motorcycles too. How many gears are they up to on those now? Some rice burners even came with a digital readout to tell you what gear you were in. Maybe if we had a motorcycle style shifter it would make more sense though. And at least the weight is in the middle of the car, plus it's stout enough we'll never break one.
But I'm a little tired of all that rowing around town, and the clutch is worse. Hopefully when I get done with my automatic upgrade though I'll have something you guys will approve of. If it works out the way I want it to. Jim |
bplus Tracy Moore Jacksonville, Fl (40 posts) Registered: 11/24/2008 06:36PM Main British Car: 71' MGB GT 350 Chevrolet |
Top two gears in the T56 are over drives, does your car run
high speed alot for the need? .63 gear in a T5 drops enough rpm for most people for highway cruising. |
