LT77 gearbox - can't select 2nd gear when cold
Hello, we recently put together a new MGB Roadster V8 conversion.
There is Rover V8 engine and LT77 gearbox. Nearly everything seems to be fine, but there is problem with 2nd gear. After a cold start I can't select 2nd gear. If I drive for a while and the engine and gearbox get warmer, it improves. The selection of 2nd gear is not excellent when warm, but would say it's acceptable. Could anybody advise me what could be wrong? Note: We bought the gearbox as a newly refurbished one and there are some new parts inside, but of course I don't know the quality of the work. |
Re: LT77 gearbox - can't select 2nd gear when cold
Does this gearbox suffer from the same intermediate shaft bearing retainer flex that the T5 does? In the T5 that can be a symptom of the preload being gone.
The more likely issue is the sync is worn out. There is a little clutch that times the gears and it's not working when it's cool because of wear. Maybe they missed that one in the rebuild. Or the part was crap. Maybe whoever did the rebuild couldn't get the stack off of that sync and figured it'd be fine. How old is the rebuild? |
Pavel,
Not an unusual problem with the LT77 mine is a bit baulky on the 1st to 2nd change until warmed up, and it has all new synchros and bearings. Do you know what lubricant was used, if gear oil instead of ATF was used that will make it worse, Kevin |
WHOA~! Good point, Kevin. I totally gapped on that. Pavel, I'm betting they used gear oil instead of ATF. Swap this out asap if it is. It will result in burning out the syncs. The symptom you are having is definitely something that happens when gear oil is used instead.
Good thinking, Kevin. |
