Solarman
Dennis mcIntyre
(20 posts)
11/09/2007 10:02PM
Gear ratio woo`s
Posted by: Solarman
Date: December 18, 2007 07:50PM
I have a Ford 8" and it has 3.4:1 ratio how will this compare to the MGB 3.9:1. Shoul I change this? what are the pros and cons?
(4637 posts)
Re: Gear ratio woo`s
Date: December 18, 2007 08:53PM
I think you might find Dan Masters' nifty calculator very helpful - this link will open as an Excel spreadsheet.
[www.britishv8.org]
If you enter gear ratios, tire diameter, etc., the calculator correlate engine speed (shift points) to road speed for you.
Citron
Stephen DeGroat
Lugoff, SC
(367 posts)
10/23/2007 09:43PM
1970 MGBGT V6, 7004R, AC, matching trailer 3.1 liter
Posted by: Citron
Date: December 18, 2007 09:00PM
Curtis,
That is a great spread sheet. I am going to try a 3.0 ratio. It will put RPM at about 2200 at 80. Just where I think it should be.
Will have to run again at MAxton and see if I'm faster that was y. Now I am at 110 at 5700 in third gear. ( 4 speed Auto.)
The new gear will put me down under 4000 at the same speed.
Steve
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Posted by: NixVegaGT
Date: December 19, 2007 08:30AM
That's a hot car, man! I love the custom headlight setup. What engine are you running now? If it's a transplant with more power I think you'll like the Ford ratio better. With more torque you won't need the extra gear and you can lower your crusing RPMs.
Solarman
Dennis mcIntyre
(20 posts)
11/09/2007 10:02PM
Posted by: Solarman
Date: December 19, 2007 08:43AM
It is a Ford 302 400hp to the wheels and 12.1 sec 1/4 mile . Light are Dodge Neon
Thanks man
