New mini starter
Jamie McClinton (Newport Start-n-Charge and a MGB-Roadmaster sponsor) is now offering a mini starter to fit the 215 for $245 shipped. He has an absolutely sterling reputation with the Buick folks, where a similar unit is used on both small block and big block Buick engines.
Jim [www.v8buick.com] |
Re: New mini starter
Jamie says that if three of us combine our purchase there's a discount to be had. I don't really need a new starter, but I was curious about several things so I sent Jamie a note. Jamie says this particular gear reduction starter weighs 9.7 pounds. I just weighed my spare vintage Buick 215 starter, and it weighs a whopping 23.0 pounds. Additionally, the gear reduction starter draws fewer amps (Jamie says between 115 and 160) so I could easily downsize my battery. Assuming I went with a compact dry cell battery, I could mount it neatly in my passenger-side footwell area, and then remove the original MGB battery box plus shorten the battery cable down to about one foot. In total, I figure there's about thirty pounds to be saved.
You may hit that target weight yet.
Re: New mini starter/ outgassing
Nitrous is so popular now, I'da thounk "someone" would have a gaseous starter. Less noise than a shotgun one. "Theres no happy endings without first getting started". roverman.
Quote: Is this different because of the block or the flywheel? What if I'm already using a 215ish flywheel? I guess I should ask Jamie… |
