Electron Beam welding
Hello out there. Anyone have first hand knowledge with this type of welding. I have a project ,in aluminum, that requires this. As a side note, this is how "Fluid Dampener", harmonic dampeners are assembled. Thanks, roverman.
Re: Electron Beam welding
It's done with an alien ray gun. No, seriously!
Ok Jim, Is that what they told you? I think I'll need to pay an american company serious change for this project. Probably "soft vac. or no vac" and "high voltage", perhaps within a "plasma window" configuration. I've personally have not used this process, but it appears to be suited for my needs. roverman.
Art, be sure to take pictures for us. EBW does make some particularly nice welds, is pretty specialized and used more for production type applications. [en.wikipedia.org]
Usually for small quantity applications other joining methods are used. Are you having a fluid damper made? Jim (It is still an alien space ray though) |
Apparently EBW is particularly well suited to making deep, narrow weld seams with penetration in the range of 2-6" with weld zones under 1/2" wide. Not building a battleship are you Art? A tank maybe?
Gentlemen.... Let's not read into this. This project is for "friendly battles only" No fluid damper, no alien abduction, maybe some blown-off doors... but that remains to be seen. Speaking of "flying", anyone run the "Maxon Mile". It's on my horizon and I could use some, first hand knowledege. Thank You fellow motorheads, roverman.
According to Steve DeGroat who is sitting on my left at the moment, it costs $50 to join the organization, website is LSR-ECTA.com Keith Kirk, costs $100(advance) or $120 for the weekend. Doesn't run in July or August. You can send Steve a PM, but he won't be back home for a few days.
HTH, Jim |
I had to Google it.
It's called the Maxton Mile & sounds like something I REALLY need to do. More info here: [www.ecta-lsr.com] |
Fellow "Speed Seekers", anyone going to "Maxton Mile" in Sept.? I plan to fly there to, "scope-it". I think my "Huffaker", would like it there. It's gonna take some Motor ! Perhaps some of us can meet there? Art from So.Cal.
Re: Electron Beam welding/ailing ray gun ?
Anybody? Perhaps you got a glimpse during their, "experiments" on you? I have the "need". My stg. II heads, have the "need". We want the power ! I can't wait another hour. Let's build a "hp. golden shower", etc. etc.roverman.
I wonder if we could weld the aluminum bore liners with this method.
UGH! What you mean we? paleface.VERY expensive for non-prodution use. Your better half is giving you an unlimited budget in 2010? If I can get two heads, "EB'd" for 300-$500,(1 weld ea.), I'll be strokin/danglin articiple, like yuse-guys.Preheat and tig is a good/cheep method for 4" bore,symesed alum.cans. Ray Gun not required,(no, not a dead president).roverman.
I guess you could just weld those tin cans top and bottom right? Any gap in the middle just lets coolant circulate? No real pressure there from the piston anyway.
Ok, now we talkin "tin" bores? I thought we workin V8's? Stainless bores? Aluminum/cast iron bores? I think I'm more confused than "bored".Can we just "hone" our chat-skills here ? you know and "focus"-like...Nic, the non-machinist who will "Tell-All".....MIKE,Jim/clan. roverman.
Re: Electron Beam welding/ P 76 ?
Bernard, nice "teaser", thanks but about as "sharing" as...MIKE ? Intakes look like P 76, could it be ? If so, Nic must find this abomination to further conjugate. Nic, 4.03 bores,(16) should be enough? At least 4" stroke? "It's hip to be square" @ Tractor Pulls ? roverman.
